- To: Tom Prince <tom.prince AT ualberta.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] apply, auto, and implicit type classes
- Date: Fri, 18 Feb 2011 14:15:20 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type; b=thlPgfucewvqpplnG9pIJhUgTImZ54J89P0VeXrZV2uZjqU1ruIcE9mVRO464I5Gxb bzyD9HxC8JsqSlNOkrN+mOCJSQqdHAgupqPzlBNSPnp0xUa82rFvZNK0bqVvscPGxsxA ZUD7J6gjzpd4NNoC0nHH/4AFZq0fA/IN/HG/c=
On Mon, Feb 14, 2011 at 9:20 PM, Tom Prince
wrote:
> I don't know whether this behaviour is expected, but the typeclass
> mechanism still has kinks and oddities in it. It would probably help if
> you gave a small self contained example of this behavior (and the
> behviour of auto) occurring.
I've given an example below of the behaviors I was describing
regarding apply, auto, and type classes. As I said, I'm not sure if
they are "bugs," but I want to wrap my head around what is going on so
that I can use the proper work-arounds.
- Aaron
<coq>
Require Import SetoidClass.
Parameter A B C: Type.
Parameter P: A -> A -> Prop.
Parameter F: A -> A.
Class K (X: Type) {S: Setoid X} := {
Q: A -> X -> X -> Prop;
Q_F:
forall a x1 x2,
Q a x1 x2 ->
Q (F a) x1 x2;
Q_sym:
forall a1 a2 x1 x2,
P a1 a2 ->
Q a1 x1 x2 ->
Q a2 x2 x1
Instance B_Setoid: Setoid B.
Instance B_K: K B.
Admitted.
Instance C_Setoid: Setoid C.
Instance C_K: K C.
Admitted.
Tactic Notation "foo" constr(e) constr(ea) :=
apply e with (1 := ea).
Lemma example_foo:
forall a1 a2 (x1 x2: C),
P a1 a2 ->
Q a1 x1 x2 ->
Q a2 x2 x1.
Proof.
intros * H1 H2.
(* foo Q_sym H1.*) (* FAILS *)
apply Q_sym with (1 := H1). (* SUCCEEDS *)
Admitted.
Create HintDb db1.
Create HintDb db2.
Create HintDb db3.
Hint Resolve Q_F: db1.
Hint Resolve @Q_F: db2.
Hint Extern 1 => apply Q_F: db3.
Lemma example_auto:
forall a (x1 x2: C),
Q a x1 x2 ->
Q (F a) x1 x2.
Proof.
intros * H.
(* auto with db1. *) (* FAILS TO SOLVE GOAL *)
(* auto with db2. *) (* SOLVES GOAL *)
(* auto with db3. *) (* SOLVES GOAL *)
Admitted.
</coq>
- [Coq-Club] apply, auto, and implicit type classes, Aaron Bohannon
- Re: [Coq-Club] apply, auto, and implicit type classes,
Tom Prince
- Re: [Coq-Club] apply, auto, and implicit type classes, Aaron Bohannon
Tom Prince
