- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Strange Ltac behavior
- Date: Wed, 23 Feb 2011 15:39:59 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type :content-transfer-encoding; b=VOFinB2tsCEQ100U+hxQCOtT2xVGVLgXDXyQd3DjNEwYoDROFdaPCY3Aui2QNJnSMv grIOzhODSmBeGAOe8gNjfF9SA1u7wFN4lOrlS5IVbAnijNO7LoruNJJJ+mqIVlMq9+EF lpawR50CHoSEKaC+FuveKU2fN3MyrRCUGKxUo=
Alternatively, instead of using a nested match, you can use
"constr_eq", which compares the ASTs of the terms. So you can do
something like this:
match goal with
| v : T ?n |- context name [?v1] => constr_eq v v1; idtac v
end.
- Aaron
On Wed, Feb 23, 2011 at 11:39 AM, Adam Chlipala
<adam AT chlipala.net>
wrote:
> Thomas Braibant wrote:
>> I have a problem that can be reduced to the snippet below.
>> Section t.
>> Variable T : nat -> Type.
>> Variable f : forall n, T n -> Prop.
>> Goal forall n m (x : T n) (y : T m), f n (x).
>> intros.
>> match goal with
>> | v : T ?n |- context name [?v] => idtac v (* prints [f n x],
>> while I would like [x]*)
>> end.
>> End.
> Hypothesis variable names are not treated as bound elsewhere in the same
> Ltac pattern. You can achieve what you want by nesting one [match] inside
> another, making each responsible for just one part of the pattern above.
- [Coq-Club] Strange Ltac behavior, Thomas Braibant
- Re: [Coq-Club] Strange Ltac behavior,
Adam Chlipala
Aaron B.
- Re: [Coq-Club] Strange Ltac behavior, Aaron Bohannon
Thomas Braibant
Thomas Braibant
Aaron B.
Adam Chlipala
