coq-club - [Coq-Club] Bug in Notations?
chronological Thread
  • Cc: coq-club AT inria.fr
  • Subject: [Coq-Club] Bug in Notations?
  • Date: Fri, 25 Feb 2011 10:24:01 +0100
I was surprised to the result of this code after deactivating the
display of notations:
Definition plus_ (m n: nat) := m.
Definition lt_ (m n: nat) := true.
Notation "n + m" := (plus_ m n).
Notation "m < n" := (lt_ m n).
Check (forall m n, (forall o, true = (m< ( n+o ) ))).
Check (forall n, (forall o, 0 = ( n+o ) )).
in the first case, n+o is interpreted as the coq defined "plus", but in
the second case it is interpreted as "plus_".
I expected "( x )" to put 'x' at level 200, so that would force the
interpretation of "x < y" to be the same in both cases.
Is there some explanation of this thing? Has this behaviour been
changed along coq versions?
Thanks
Cédric.
