- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Bug in Notations?
- Date: Fri, 25 Feb 2011 12:28:08 +0100
Hi Cedric,
What you observe is due to scopes:
- The + notation for plus is in scope nat_scope.
- The + notation for plus_ is "lonely" (i.e. in no scope) and it is
hence the default interpretation in the current context.
- Interpreting < as lt_ in the first example forces its arguments to
be preferably interpreted in nat_scope (because the type of the
arguments of lt_, nat, is bound to nat_scope), thus taking
precedence over the interpretation of + as plus_.
- Interpreting = does not affect the scope of its arguments, hence the
arguments of = are interpreted using the default interpretation, which
interprets + as plus_.
More can be found in section 12.2.1 of the reference manual (Global
interpretation rules for notations).
Hugo
On Fri, Feb 25, 2011 at 10:24:01AM +0100, AUGER Cedric wrote:
> I was surprised to the result of this code after deactivating the
> display of notations:
> Definition plus_ (m n: nat) := m.
> Definition lt_ (m n: nat) := true.
> Notation "n + m" := (plus_ m n).
> Notation "m < n" := (lt_ m n).
> Check (forall m n, (forall o, true = (m< ( n+o ) ))).
> Check (forall n, (forall o, 0 = ( n+o ) )).
> in the first case, n+o is interpreted as the coq defined "plus", but in
> the second case it is interpreted as "plus_".
> I expected "( x )" to put 'x' at level 200, so that would force the
> interpretation of "x < y" to be the same in both cases.
> Is there some explanation of this thing? Has this behaviour been
> changed along coq versions?
> Thanks
> Cédric.
- [Coq-Club] Job Opportunities at Kestrel Institute, coglio
- [Coq-Club] Bug in Notations?,
AUGER Cedric
- Re: [Coq-Club] Bug in Notations?, Hugo Herbelin
AUGER Cedric
