- From: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Mutually recursive lemmas and decreasing arguments
- Date: Fri, 11 Mar 2011 01:53:20 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:from:date:x-google-sender-auth:message-id :subject:to:content-type; b=IjsIfUkyizSzP1H0AqgDRgupq47BuDAUQ67zmdqGtr/Wh9lEKTSbx0LSR7Xop+BMXi inb2JDsQUwfijkwZ6wueNW2JsjhmZ1lqz651hEEaydgrb2IzSqVF623Jb0vTc5QTLnBs 6juoLv5qkZRtISC9E1UZO+ClWYC/6y/7K7o+Q=
Dear list
I have three mutually recursive inductive on which I would like to
prove three mutually recursive lemmas.
The proof itself goes well (it's a few line, with almost no automation
to avoid using a lemma to prove itself). It is at the Qed that
everything goes wrong. After a time between 30 minutes and a few hours
(I gave up watching it), and without really increasing its memory
usage, Coq answers "Error: Cannot guess decreasing argument of fix.".
I guess the long time is due to the fact coq checks all the
combination of possible decreasing argument. So my first question is:
is there a way to specify the decreasing arguments on lemmas, so that
the checking goes faster. Because I can't try new proofs if it always
take 2 hours to check them...
In the mean time, I tried to prove it using Program. I tried to do this
Program Fixpoing lemma1 arg11 ... arg1n {struct arg1i}: concl1 := _
with lemma2 arg21...arg2p {struct arg2j} := _
But it does not work. When solving the obligation for lemma1, lemma2
is not accessible. Is that a bug or a feature ?
Thanks for the help
- Alexandre
- [Coq-Club] Mutually recursive lemmas and decreasing arguments, Alexandre Pilkiewicz
- Re: [Coq-Club] Mutually recursive lemmas and decreasing arguments,
Adam Chlipala
- Re: [Coq-Club] Mutually recursive lemmas and decreasing arguments, Alexandre Pilkiewicz
- Re: [Coq-Club] Mutually recursive lemmas and decreasing arguments, Matthieu Sozeau
Adam Chlipala
