- To: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Mutually recursive lemmas and decreasing arguments
- Date: Thu, 10 Mar 2011 19:57:40 -0500
Alexandre Pilkiewicz wrote:
I have three mutually recursive inductive on which I would like to
prove three mutually recursive lemmas.
The proof itself goes well (it's a few line, with almost no automation
to avoid using a lemma to prove itself). It is at the Qed that
everything goes wrong. After a time between 30 minutes and a few hours
(I gave up watching it), and without really increasing its memory
usage, Coq answers "Error: Cannot guess decreasing argument of fix.".
I guess the long time is due to the fact coq checks all the
combination of possible decreasing argument. So my first question is:
is there a way to specify the decreasing arguments on lemmas, so that
the checking goes faster. Because I can't try new proofs if it always
take 2 hours to check them...
Are you using an induction principle generated by [Scheme]? There shouldn't be any need for explicit [fix]es if so.
- [Coq-Club] Mutually recursive lemmas and decreasing arguments, Alexandre Pilkiewicz
- Re: [Coq-Club] Mutually recursive lemmas and decreasing arguments, Adam Chlipala
- Re: [Coq-Club] Mutually recursive lemmas and decreasing arguments, Alexandre Pilkiewicz
- Re: [Coq-Club] Mutually recursive lemmas and decreasing arguments, Matthieu Sozeau
