- To: Daniel Schepler <dschepler AT gmail.com>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Typeclasses and implicit arguments
- Date: Thu, 10 Mar 2011 20:13:30 -0500
On 2011-03-10, Daniel Schepler wrote:
> Let me add my own question on typeclasses:
> Suppose I define
> Generalizable All Variables.
> Class ExtEqual {X Y} (f g:X->Y) : Prop :=
> extensional_equality : forall x:X, f x = g x.
> Class injective `(f:X->Y) : Prop :=
> injectivity: forall x1 x2:X, f x1 = f x2 -> x1 = x2.
> Instance injective_properness
> `{ExtEqual X Y f g} `{injective _ _ f} :
> injective g.
> Here why do I have to fill in the implicit arguments for ExtEqual and
> injective? Is that the intended behavior?
You can get the usual handling of implicit arguments by inserting ! at
the begining of an generalizing binder, which also turns off the
implicit generalization of unspecified arguments. I don't know what the
rational for this behaviour is.
> Also, it seems if I add too many instances along these lines (fg injective
> g injective, id injective and surjective, etc.) I tend to end up with the
> resolver failing in simple situations, and "typeclasses eauto" looping.
I think that this is a known issue. I don't know of any general
workarounds. One suggestion that I have seen for some cases, is to add a
hint conditioned with a more specific pattern to the typeclass_instances
database. (An instance is, as far as I can tell, essentially a hint in
this databse)
Tom
- [Coq-Club] Typeclasses and implicit arguments, Daniel Schepler
- Re: [Coq-Club] Typeclasses and implicit arguments, Tom Prince
- Re: [Coq-Club] Typeclasses and implicit arguments, Matthieu Sozeau
