- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Notations for patterns
- Date: Fri, 11 Mar 2011 07:41:03 +0000
- Accept-language: en-GB, en-US
Hi all
I'd like to define a notation that doubles up as both a term and a pattern.
As far as I can tell, Coq has a look at the right-hand-side of the Notation
definition and attempts to interpret it as both a term and a pattern, but
unfortunately doesn't tell you when it fails to interpret it as a pattern
until you actually use it. I'm having problems persuading Coq to accept
notations for patterns that contain "_" standing for *index* arguments. This
works:
Inductive BITS :=
| NIL : BITS
| CONS : bool -> BITS -> BITS.
Notation "b .0" := (CONS false b) (at level 2).
Definition LSBZero x := match x with b.0 => true | _ => false end.
It even works if I spuriously parameterize BITS:
Inductive BITS (n:nat) :=
| NIL : BITS n
| CONS : bool -> BITS n -> BITS n.
Notation "b .0" := (CONS _ false b) (at level 2).
Definition LSBZero (x : BITS 5) := match x with b.0 => true | _ => false end.
But now if I try and *index* BITS by a nat, it fails:
Inductive BITS : nat -> Type :=
| NIL : BITS 0
| CONS : forall n, bool -> BITS n -> BITS (S n).
Definition LSBZero (x:BITS 5) := match x with b.0 => true | _ => false end.
I get the following error in the definition of LSBZero:
Toplevel input, characters 97-100:
Error: Invalid notation for pattern.
Any idea what Coq doesn't like?
Cheers
Andrew.
- [Coq-Club] Notations for patterns, Andrew Kennedy
- Re: [Coq-Club] Notations for patterns,
AUGER Cedric
- RE: [Coq-Club] Notations for patterns, Andrew Kennedy
AUGER Cedric
