- From: Frederic Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] What about a Coq ExtLib ?
- Date: Fri, 11 Mar 2011 10:16:10 +0800
Hello.
I think that this is an interesting idea to have a kind of open standard library that could be contributed by anyone following some guidelines.
Le 10/03/2011 13:39, Tom Prince a écrit :
Also, there is the issue of compatibility. There needs to be a balanceBut I don't think we need to worry too much about backward compatibilities with old contributions or the current standard lib, because we can simply use new name spaces.
between improving the library, and supporting code that worked against
older versions. It wouldn't surprise me if a number of the perceived
deficiencies of the standard library are due to the requirement to be
backwards compatible. I think to a certain extent, both the goals that I
outlined above run counter to maintaining backward compatibility. I
don't think this is an insurmountable challenge, but certainly, at
points it will lead to non-perfect code.
Frederic.
- [Coq-Club] What about a Coq ExtLib ?, Thomas Braibant
- Re: [Coq-Club] What about a Coq ExtLib ?,
Aaron Bohannon
Tom Prince
AUGER Cedric
- Re: [Coq-Club] What about a Coq ExtLib ?, Gregory Malecha
- Re: [Coq-Club] What about a Coq ExtLib ?, Frederic Blanqui
AUGER Cedric
- Re: [Coq-Club] What about a Coq ExtLib ?, Thomas Braibant
Peter Aczel
- Re: [Coq-Club] What about a Coq ExtLib ?, AUGER Cedric
Tom Prince
- [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?,
Hugo Herbelin
- Re: [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?,
Daniel Schepler
Tom Prince
- Re: [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?, Thomas Braibant
- Re: [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?, Frederic Blanqui
Tom Prince
Daniel Schepler
- Message not available
- [Coq-Club] Re: [coqdev] What about a Coq ExtLib ?, Thomas Braibant
Aaron Bohannon
