- To: Thomas Strathmann <thomas AT pdp7.org>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Iterating Ltac tactics
- Date: Mon, 21 Mar 2011 12:14:50 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=0YLwKyI3JqZvTOHhSRd80/GSpv1dfVpfvVGYgEicc9l22M8x76OWZ+9AJQYLOkNFaM7j3z/F0WUdlOjKhokwdaZAYEhQM7LMOvid6FGC7Rs9onvw8AIEyz5WWDzJHxxLXqwwgbvNoLsCpjp0vD3voZP4LI47807cQXLg8BSTgf8=;
> On 2001-03-21 9:18:54 AM Thomas Strathmann
> On 3/21/11 15:10 , Adam Chlipala wrote:
> > Thomas Strathmann wrote:
> >> I've yet to find a way to apply a tactic T again and again to the
> >> current goal exactly like
> >> T. T. T. T. T. ...
> > Perhaps [repeat T] would do? None of the structured Ltac support
> > duplicates exactly the semantics of the period operator, as far as I
> > know, but that's a feature, not a bug. :)
> Sadly, it doesn't. I should have mentioned that [repeat T] behaves like
> [T] in
>this particular situation. I had this ominous feeling that it might be a
>feature that what I want to do is not supported (directly).
> It's not earth shattering, but it would have been nice to be able to
> automate
>just a tad more given that among other reasons I was drawn to Coq because
>of
>the automation facilities.
I'm having trouble thinking of a case where repeatedly applying T works, but
adding a ; (try T) somewhere earlier
in the derivation is not successful.
Please provide a bit more detailed example.
I've found ; is almost always usable, but you may have to group some manual
steps with [|], so that
a case split plus some subsequent solving is a single tactic expression you
can
extend with ; try T.
abbreviations here can be helpful
I'll often manually work out some proof steps like
destruct x. A (* solve first case *). B (* solves second case *). (* now,
lots
of leftover cases T solves *)
Then group them as
destruct x;[A|B|..].
which can be completed like
destruct x;[A|B|..];solve[T].
The abbreviations can be pretty handy:
http://coq.inria.fr/refman/Reference-Manual012.html#htoc306
You haven't mentioned existential variables, but if they are
involved then "instantiate" might help. It applies all the instantiations
made in earlier branches of a [||] split to the current goal, to replace
the effect of "." automatically propagating the instantiations to
other remaining goals after applying your tactic.
Brandon
- [Coq-Club] Iterating Ltac tactics, Thomas Strathmann
- Re: [Coq-Club] Iterating Ltac tactics,
Adam Chlipala
Thomas Strathmann
- Re: [Coq-Club] Iterating Ltac tactics, Adam Chlipala
AUGER Cedric
- Re: [Coq-Club] Iterating Ltac tactics, Thomas Strathmann
- Re: [Coq-Club] Iterating Ltac tactics, Brandon Moore
Thomas Strathmann
- Re: [Coq-Club] Iterating Ltac tactics, Matthieu Sozeau
Adam Chlipala
