- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Iterating Ltac tactics
- Date: Tue, 22 Mar 2011 15:51:15 +0100
On 3/21/11 15:33 , AUGER Cedric wrote:
Can you tell us more of your "T" tactic and the context where you want
to apply it a certain number of times?
The tactic T in this case does nothing more fancy than applying the constructors of an inductively defined relation (reduction relation for a combinatory logik) based on what the head of the term to be reduced looks like (i.e. if it's a weak redex like [S x y z], a weak normal form
or the application of a weakly reducible term to another term that may or may not be already in normal form). Invoking the rules dealing with
transitivity and "uncovering" a weak redex that is "buried" under a (number of) applications necessarily produces more than one subgoal, but after those are proved I'm left with just one goal and in most cases I can actually solve the whole obligation by repeating T a number of times using the . tactical (or whatever else I should call it). I suspected that there's some conceptual error on my part, but because of your replies I am now pretty certain that I should reorganize the tactic and have made some progress towards a (partial) solution to my original problem. But, as I already mentioned, it's not really that important for the overall development, and so it's kind of on the back burner for now. Thanks for all your kind replies and offers of help, but I have had the experience that in order to really understand something it's not sufficient to look at solutions or hints provided by other people, but to come up with a solution oneself (apart from the fact that sadly I don't really have the time to engage in a discussion of particulars of my development).
Thomas
- [Coq-Club] Iterating Ltac tactics, Thomas Strathmann
- Re: [Coq-Club] Iterating Ltac tactics,
Adam Chlipala
Thomas Strathmann
- Re: [Coq-Club] Iterating Ltac tactics, Adam Chlipala
AUGER Cedric
- Re: [Coq-Club] Iterating Ltac tactics, Thomas Strathmann
- Re: [Coq-Club] Iterating Ltac tactics, Brandon Moore
Thomas Strathmann
- Re: [Coq-Club] Iterating Ltac tactics, Matthieu Sozeau
Adam Chlipala
