coq-club - Re: [Coq-Club] Impredicative [ Set ]
chronological Thread
  • From: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: gmalecha AT cs.harvard.edu, Coq-Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Impredicative [ Set ]
  • Date: Sat, 16 Apr 2011 01:09:58 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type; b=bYv4S5hV1e14ZYKi69wJEXgeiG/Q5rfVo8Mj5JkSPDQUp2FMK/uuw9bCzs/Co8TCKg tR+RQDEgAB7iBlDBBA3NfNuw0oacTFuO6CRpe9aE3yL5OxIhAnFxuNEtaNkTRt63FOwS P9Hzr2kvko9HIeHCXu4uDILdtz1/BG93tnLKw=
Hi!
When I use proof general,  I usually have a small shell script that looks like that
#!/bin/sh
PWD=`pwd`
make depend
make -q ${1}o || {
    make -j2 `grep "^${1}o" .depend | sed -e 's/.*://'`
COQPROGNAME="coqtop"
COQPROGARGS="\"-I\" \"$PWD/TCB\" \"-I\" \"$PWD/NTCB\""
emacs --eval "(setq coq-prog-name \"$COQPROGNAME\")" \
 --eval "(setq coq-prog-args '($COQPROGARGS))" $1
&& make ${1}o
You can easily add -impredicative-set in the COQPROGARGS list
Cheers
Alexandre
