coq-club - [Coq-Club] Re: [coqdev] messy behavior with universes
chronological Thread
  • To: Vladimir Voevodsky <vladimir AT ias.edu>, Coq-Club Club <coq-club AT inria.fr>
  • Cc: coqdev AT inria.fr
  • Subject: [Coq-Club] Re: [coqdev] messy behavior with universes
  • Date: Fri, 15 Apr 2011 19:24:20 -0400
On 2011-04-15, Vladimir Voevodsky wrote:
> In the following example:
> File 1 (ex1.v) :
> Definition dneg (X:Type) := ((X -> Empty_set) -> Empty_set).
> File 2 (ex2.v):
> Require Export ex1.
> Variable X:Set.
> Check (dneg X).
> Check ((X -> Empty_set)-> Empty_set).
> Coq responds that (dneg X) is in Type while ((X -> Empty_set)-> Empty_set)
> is in Set. This does not look right.
This is expected. Everything in Set is also in type, so
Check ((X -> Empty_set)-> Empty_set) : Type.
Unfortunately, coq doesn't currently support looking through the
definition of dneg to see that (dneg X) is convertible with a term of
sort Set.
There is limited support for doing this with paramaters of inductives,
but nothing else.
  Tom
