- To: Marko Maliković <marko AT ffri.hr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Universal quantified hypothesis
- Date: Mon, 25 Apr 2011 18:53:10 +0200
Le Mon, 25 Apr 2011 18:08:51 +0200 (CEST),
Marko Maliković
<marko AT ffri.hr>
a écrit :
> Hello all,
> Perhaps the following question is naive but I do not find a solution:
> Is it possible context, which contains a hypothesis with dependent
> product, for example:
> H : forall A : Prop, A
> goal
> into the context with quantifier free hypothesis:
> A : Prop
> H : A
> goal
> Are the above two proofs equivalent at all?
> Thanx and greetings,
> Marko Maliković
Your question is not clear, but your first case is rather a proof of
"(forall A, A) -> goal" (which is trivial to prove, just apply H), and
the second is rather a proof of "forall A, A -> goal" (which may be
non trivial or even false, depending on "goal").
So, as the things to prove are different, I guess that knowing if the
proofs are equivalent has no real meaning.
What is equivalent is rather:
A: Prop
H: A
goal
A: Prop
forall (H:A) -> goal
" and
forall (A:Prop) (H:A) -> goal
but I guess you already know it
- [Coq-Club] Function command, Randy Pollack
- Re: [Coq-Club] Function command,
julien forest
Randy Pollack
- [Coq-Club] Universal quantified hypothesis,
Marko Malikoviæ
- Re: [Coq-Club] Universal quantified hypothesis, AUGER Cedric
- Re: [Coq-Club] Universal quantified hypothesis, Marko Malikoviæ
Marko Malikoviæ
Randy Pollack
julien forest
