- To: Gregory Malecha <gmalecha AT eecs.harvard.edu>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] apply <- in Bug?
- Date: Thu, 28 Apr 2011 09:18:15 +0200
Hi,
> I'm trying to write a tactic that will convert equivalences on N to
> equivalences on nat, but I'm having a problem applying nat_compare_lt to a
> hypothesis that I find using a match. I've boiled it down to this simple
> example:
> Require Import Compare_dec.
> Goal forall a b, nat_compare a b = Lt -> True.
> intros.
> (** If I do: **)
> apply <- nat_compare_lt in H. (** it succeeds **)
> (** If I do: **)
> match goal with
> | [ H : _ |- _ ] => idtac H;
> end. (** it fails but it prints H as one of the hypotheses tried **)
> Is this a bug? Does anyone know of a way to work around this?
Yes, this is a bug. You can either retrieve and compile the svn 8.3 or
trunk version, or simply temporarily overwrite the "apply <- ... in ..."
and "apply -> ... in ..." tactic notations by adding the following
lines to your file:
Tactic Notation "apply" "->" constr(lemma) "in" hyp(J) :=
bapply lemma ltac:(fun H => destruct H as [H _]; apply H in J).
Tactic Notation "apply" "<-" constr(lemma) "in" hyp(J) :=
bapply lemma ltac:(fun H => destruct H as [_ H]; apply H in J).
Best regards,
Hugo Herbelin
- [Coq-Club] apply <- in Bug?, Gregory Malecha
- Re: [Coq-Club] apply <- in Bug?, Hugo Herbelin
