- To: Michael Shulman <mshulman AT ucsd.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] metavariable binding in Ltac
- Date: Thu, 28 Apr 2011 10:14:36 +0200
Hi,
On Mon, Apr 25, 2011 at 08:25:11PM -0700, Michael Shulman wrote:
> I am confused by some behavior of metavariable binding in Ltac. This
> works as I would expect:
> Lemma test {A B} (f : forall x:A, B x) (a : A) : B a.
> Proof.
> match goal with
> | |- B ?y => apply f with (x := y)
> end.
> Qed.
> But this doesn't (just replace both y's with x):
> Proof.
> match goal with
> | |- B ?x => apply f with (x := x)
> end.
> Qed.
> It seems to me that there should be no difference; isn't the latter
> just an alpha-conversion of the first? Surely the 'x' on the
> left-hand side of the := exists in a different scope (the dependent
> arguments of f) and shouldn't be affected by the name of a local
> metavariable? Or is there some other subtlety I'm missing?
The choice to allow the x on the left-hand side of := to be possibly
given as a parameter of the ltac expression goes back to the initial
design of Ltac. As soon as it is always possible to alpha-convert the
code as you did in the first example, I do not see any real problem
in keeping this feature, even if it might be a bit surprising when we
experiment your second example.
Hugo Herbelin
- [Coq-Club] metavariable binding in Ltac, Michael Shulman
- Re: [Coq-Club] metavariable binding in Ltac, Hugo Herbelin
- [Coq-Club] PxTP, Extended Deadline, Laurent Théry
