- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: "Benjamin C. Pierce" <bcpierce AT cis.upenn.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] proof tree visualization
- Date: Fri, 29 Apr 2011 11:33:18 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type; b=axD78UtJO5vdHzbq2ITPPvDypQQtoaqmmfSaYEBq6X3axG61hZxXmt9XBZJDoHVoaC TI6lKWPb3yIT3/cp/WRMiT/qqqhMbvkaQ6yl7OrW8GpJm2kJ1My+sZ/G/4gSJdht4V0B 69uOuk4ws7fRcWENBvbnNXcKbDT3DGyi8xt5g=
It is quite likely that such features make their way to Coq. Though not for the next release I'm afraid.
Arnaud Spiwack
On 26 April 2011 18:41, Benjamin C. Pierce <bcpierce AT cis.upenn.edu> wrote:
>> I find Aaron Bohannon's Case tactics to be extremely helpful for this.Wow -- this looks really nice! It seems to solve one of the main issues with Aaron's tactics -- that you have to hand-code the list of constructors for each inductive type.
> And this gives me a new occasion to advertise for my extension of those tactics!
> https://github.com/pilki/cases
Any chance this feature could eventually be included in Coq by default?
- B
> It allows you to:
> * like Aaron's tactic, comment your proof scripts and make your proof
> scripts more robust, through those comments
> * Automatically tag the subcases of an induction: if n is of type nat,
> induction' n as [|p] tags the first subcase with "O" and the second
> with "S p". This works with any inductive without extra work.
> * Automatically tag subgoals when a lemma/constructor has named
> hypothesis: if you have a lemma
> Lemma lt_is_le: forall m n (LT:m < n), m <= n). omega. Qed.
> Then "apply' lt_is_le" produces a sugboal taged "LT".
> This is obviously way more usefull when you have many subgoals, with
> several of them being proved automatically (by auto for example). And
> if one day, auto proves less, or more goals, the proof script fails
> loudly exactly where the problem occurs.
> * Automatically generate a tag from the names of arguments:
> with the simpl tactic:
> Ltac destr_eq_nat_dec n1 n2 :=
> string_of n1 (fun strn1 =>
> string_of n2 (fun strn2 =>
> destruct (eq_nat_dec n1 n2);
> [ fst_Case_tac (strn1 ^^ " = " ^^ strn2)
> | fst_Case_tac (strn1 ^^ " <> " ^^ strn2)])).
> if you write "destr_eq_nat n 42", the first subgoal is taged with "n =
> 42" and the second with "n <> 42"
> * with a small emacs function (included in the distribution), you can
> import those tags directly in your proof script without typing them
> Cheers
> Alexandre
- [Coq-Club] proof tree visualization, Hendrik Tews
- <Possible follow-ups>
- Re: [Coq-Club] proof tree visualization,
Alexandre Pilkiewicz
Benjamin C. Pierce
- Re: [Coq-Club] proof tree visualization, Arnaud Spiwack
Benjamin C. Pierce
