- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] how to represent the assumption of a finite set
- Date: Fri, 06 May 2011 13:07:13 +0200
On 5/6/11 10:38 , Gyesik Lee wrote:
many languages are based on a finite set of symbols.
I am wondering how to represent phrases such as "Let L be a finite set
of constants".
On paper, we usually say, L is indexed by numbers less than a natural number.
Is there a simple, intuitive way to do the same thing in Coq?
Any help will be appreciated.
You can do the latter in Coq by defining an inductive type of natural numbers less than n that you can use in much the same way as you would [nat].
Inductive fin : nat -> Type :=
| FO : forall n, fin (S n)
| FS : forall n, fin n -> fin (S n).
Implicit Arguments FO [n].
Implicit Arguments FS [n].
Thomas
- [Coq-Club] how to represent the assumption of a finite set, Gyesik Lee
- <Possible follow-ups>
Gyesik Lee
- Re: [Coq-Club] how to represent the assumption of a finite set,
Vincent
- Re: [Coq-Club] how to represent the assumption of a finite set, Damien Pous
Damien Pous
- Re: [Coq-Club] how to represent the assumption of a finite set, Alexandre Pilkiewicz
- Re: [Coq-Club] how to represent the assumption of a finite set, Thomas Strathmann
Vincent
