coq-club - Re: [Coq-Club] how to represent the assumption of a finite set
chronological Thread
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] how to represent the assumption of a finite set
  • Date: Fri, 6 May 2011 13:50:59 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=ZItCmZpqhSLruBUvDRR2kAu4gF6Rr2t+zteohoU77MlVYWkAHySid1iuGIIH+0Wr6h TdiQxpNtTJlgTqqu1km12gDXMyJz99zykj8wei/PPJAHjxr4niEdsESIXEORX/RAx1I+ 9caDpg1qpwv/LG1QVf45fNFlj3GwGbiQP4MOk=
Sebastien Briais also used the following trick:
Assume an arbitrary set and a list over that set, and consider the set
of elements of that list.
Variable U: Set.
Variable X: list U.
Goal forall x, In x U -> x = x.
Depending on what you want to do, this might do the job.
Damien
2011/5/6 Vincent
<vincent.siles AT gmail.com>:
> Hi Gyesik,
> I think the two usual ways to do this in Coq is to use the Finite
> predicate (Finite_sets.v),
> or to use the FSet Module interface.
> There are some new attempts to define Finite sets with Co-Inductive or
> Accessibility-like
> predicates, but they are still under investigation, and they are not
> in the stdlib.
> Cheers,
> Vincent
> 2011/5/6 Gyesik Lee
> <leegys AT gmail.com>:
>> Hi,
>> many languages are based on a finite set of symbols.
>> I am wondering how to represent phrases such as "Let L be a finite set
>> of constants".
>> On paper, we usually say, L is indexed by numbers less than a natural
>> number.
>> Is there a simple, intuitive way to do the same thing in Coq?
>> Any help will be appreciated.
>> Gyesik
