- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Extraction and error reporting
- Date: Mon, 9 May 2011 11:47:38 +0200
Ok, my short tutorial is published on cocorico.
Le Sun, 8 May 2011 13:30:15 +0200,
AUGER Cedric
a écrit :
> Le Sat, 7 May 2011 01:47:47 +0200,
> a
> écrit :
> > Dear list
> > I'm trying report some errors in my code by adding things like
> > Parameter error_badly_masked: unit -> unit.
> > Extract Constant error_badly_masked => "Errors.error_badly_masked".
> > Definition .....
> > let tt := error_badly_masked tt in
> > But the extraction removes this call
> > Is it possible to forbid the extraction to remove call to
> > parameters?
> > Thanks in advance
> > Alexandre
> I suggest you to deactivate optimizations of the extractor:
> Unset Extraction Optimize.
> If you use "tt" in the rest of the code, that should do the trick,
> else, you have to destructure it, to force the dependence to your
> function call:
> Definition .....
> let () := tt in
> But do you really need to perform some "Extraction constant ..."?
> As P. Letouzey wrote in this list, it is an "unsafe" feature, you
> really need some extra care if you want your code to be really
> correct.
> As I guess you "error_badly_masked" is an exception raiser, you may
> consider using an error monad. I am currently writting a short
> tutorial on extraction that I hope to post on the cocorico wiki. I
> guess I am not good at it, but it may be shorter for you (when it
> will be done) than having a look at the Compcert Project (since it is
> a big project).
> Here is a link if you want to take a look at this project on how to
> manage errors.
> http://compcert.inria.fr/doc/html/Errors.html
- [Coq-Club] Extraction and error reporting, Alexandre Pilkiewicz
- Re: [Coq-Club] Extraction and error reporting, Francesco Zappa Nardelli
AUGER Cedric
- [Coq-Club] Re: Extraction and error reporting, Alexandre Pilkiewicz
- Re: [Coq-Club] Extraction and error reporting, AUGER Cedric
