- From: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Extraction and error reporting
- Date: Sat, 7 May 2011 01:47:47 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:from:date:x-google-sender-auth:message-id :subject:to:content-type; b=sI8x+HTFtrb9VmuMHveuGy0xeejUgGfZBpVE+yKR82LHo8BnXgHOA6Nsl2P+egWnXz DrK6DfLJQGKpAl7bsti3OP1GxONbaL9asHM5V59JE9cdLP+9KPu4jx2krNNbCu0RQ6IS kLKWhE+1sdpLVZ3bYBQxu0YLjoYiSLTncAxIA=
Dear list
I'm trying report some errors in my code by adding things like
Parameter error_badly_masked: unit -> unit.
Extract Constant error_badly_masked => "Errors.error_badly_masked".
Definition .....
let tt := error_badly_masked tt in
But the extraction removes this call
Is it possible to forbid the extraction to remove call to parameters?
Thanks in advance
Alexandre
- [Coq-Club] Extraction and error reporting, Alexandre Pilkiewicz
- Re: [Coq-Club] Extraction and error reporting, Francesco Zappa Nardelli
AUGER Cedric
- [Coq-Club] Re: Extraction and error reporting, Alexandre Pilkiewicz
- Re: [Coq-Club] Extraction and error reporting, AUGER Cedric
