- From: Julien Tesson <julien.tesson AT univ-orleans.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] using context in Ltac
- Date: Tue, 17 May 2011 20:03:56 +0200
Le 11/05/2011 11:44, Julien Tesson a écrit :
> Hi,
> I am trying to use Ltac and context to do something like
> Ltac f x :=
> match x with
> context f [ SomeTermIwantToReplace ] => let x':=fun p => context f[
> a_replacement_function p]
> in assert (forall p, (x' p))
> end.
> but this syntax dos not work and I was unable to find a way to do it.
> After a discussion on the IRC channel I try miscellaneous attempt :
> http://pastebin.com/aJ3vQ1kz .
> Here I really need to have, after I prove the assertion, an hypothesis like
> this [forall p , x' p],
> so I cannot first introduce p to the environment and then apply the
> replacement tactic.
> As someone any idea on how to proceed ?
The reason seems to be that "context f[ a_replacement_function p]" as to be
a type checkable term, is it true ?
Is it a desired feature, or just a technical constraint in the Ltac
implementation ?
Actually, it would be sometimes very practical to generate a kind of
preterm with a tactic, and to be able to pass it to other tactics.
Julien Tesson
Doctorant - ATER
Laboratoire d'Informatique Fondamentale d'Orléans
Département Informatique
Université d'Orléans
Tel : 02 38 49 25 81
Fax : 09 56 45 86 27
http://tesson.julien.free.fr/
- [Coq-Club] using context in Ltac, Julien Tesson
- Re: [Coq-Club] using context in Ltac, Julien Tesson
