- To: Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: Coq-Club Club <coq-club AT inria.fr>, homotopytypetheory AT googlegroups.com
- Subject: Re: [Coq-Club] an update to "Univalent Foundations"
- Date: Tue, 17 May 2011 22:48:50 +0200
Dear Vladimir,
Can we do usual ZFC set theory (maybe with one or two Grothendieck-Tarski
universes) in your foundational setup?
If so, is there then furthermore a way of relating it to the more
general types you consider?
Thanks
---Carlos
Selon Vladimir Voevodsky
<vladimir AT ias.edu>:
> Hello,
> I have just posted an update to the "Univalent Foundations" library to my
> github at https://github.com/vladimirias/Foundations/
> The most important new thing in this release is the construction of true
> set-quotients of types.
> Vladimir.
- [Coq-Club] how a client should check a Coq proof for cheating?, Georgi Guninski
- <Possible follow-ups>
- Re: [Coq-Club] how a client should check a Coq proof for cheating?,
Bruno Barras
- Re: [Coq-Club] how a client should check a Coq proof for cheating?, Georgi Guninski
- [Coq-Club] an update to "Univalent Foundations",
Vladimir Voevodsky
- Re: [Coq-Club] an update to "Univalent Foundations", Carlos Simpson
Vladimir Voevodsky
- Re: [HoTT] Re: [Coq-Club] an update to "Univalent Foundations",
Thomas Streicher
Carlos Simpson
- Re: [HoTT] Re: [Coq-Club] an update to "Univalent Foundations", Thomas Streicher
Carlos Simpson
Thomas Streicher
Vladimir Voevodsky
