coq-club - Re: [Coq-Club] Init/Peano.v
chronological Thread
  • Cc: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Init/Peano.v
  • Date: Thu, 19 May 2011 11:38:19 +0200
Le Thu, 19 May 2011 06:26:18 -0400,
Vladimir Voevodsky
<vladimir AT ias.edu>
 a écrit :
> Hello,
> where can I find the source (.v file ) for the basic library e.g.
> Init/Peano.v ? It does not appear to be in the usual sources.
> V.
Strange, I have it in "($COQ)/theories/Init/Peano.v"
Maybe we don't have the same version. (I use an old trunk version of
the 8.3, but I guess it didn't changed since)
(*  v      *   The Coq Proof Assistant  /  The Coq Development Team     *)
(* <O___,, *   INRIA - CNRS - LIX - LRI - PPS - Copyright 1999-2010     *)
(*   \VV/  **************************************************************)
(*    //   *      This file is distributed under the terms of the       *)
(*         *       GNU Lesser General Public License Version 2.1        *)
(** The type [nat] of Peano natural numbers (built from [O] and [S])
    is defined in [Datatypes.v] *)
(** This module defines the following operations on natural numbers :
    - predecessor [pred]
    - addition [plus]
    - multiplication [mult]
    - less or equal order [le]
    - less [lt]
    - greater or equal [ge]
    - greater [gt]
   It states various lemmas and theorems about natural numbers,
   including Peano's axioms of arithmetic (in Coq, these are provable).
   Case analysis on [nat] and induction on [nat * nat] are provided too
Require Import Notations.
Require Import Datatypes.
Require Import Logic.
Unset Boxed Definitions.
Open Scope nat_scope.
Definition eq_S := f_equal S.
Hint Resolve (f_equal S): v62.
Hint Resolve (f_equal (A:=nat)): core.
(** The predecessor function *)
Definition pred (n:nat) : nat := match n with
                                 | O => n
                                 | S u => u
                                 end.
Hint Resolve (f_equal pred): v62.
Theorem pred_Sn : forall n:nat, n = pred (S n).
Proof.
  simpl; reflexivity.
Qed.
(** Injectivity of successor *)
Definition eq_add_S n m (H: S n = S m): n = m := f_equal pred H.
Hint Immediate eq_add_S: core.
Theorem not_eq_S : forall n m:nat, n <> m -> S n <> S m.
Proof.
  red in |- *; auto.
Qed.
Hint Resolve not_eq_S: core.
Definition IsSucc (n:nat) : Prop :=
  match n with
  | O => False
  | S p => True
  end.
(** Zero is not the successor of a number *)
Theorem O_S : forall n:nat, 0 <> S n.
Proof.
  discriminate.
Qed.
Hint Resolve O_S: core.
Theorem n_Sn : forall n:nat, n <> S n.
Proof.
  induction n; auto.
Qed.
Hint Resolve n_Sn: core.
(** Addition *)
Fixpoint plus (n m:nat) : nat :=
  match n with
  | O => m
  | S p => S (p + m)
  end
where "n + m" := (plus n m) : nat_scope.
Hint Resolve (f_equal2 plus): v62.
Hint Resolve (f_equal2 (A1:=nat) (A2:=nat)): core.
Lemma plus_n_O : forall n:nat, n = n + 0.
Proof.
  induction n; simpl in |- *; auto.
Qed.
Hint Resolve plus_n_O: core.
Lemma plus_O_n : forall n:nat, 0 + n = n.
Proof.
  auto.
Qed.
Lemma plus_n_Sm : forall n m:nat, S (n + m) = n + S m.
Proof.
  intros n m; induction n; simpl in |- *; auto.
Qed.
Hint Resolve plus_n_Sm: core.
Lemma plus_Sn_m : forall n m:nat, S n + m = S (n + m).
Proof.
  auto.
Qed.
(** Standard associated names *)
Notation plus_0_r_reverse := plus_n_O (only parsing).
Notation plus_succ_r_reverse := plus_n_Sm (only parsing).
(** Multiplication *)
Fixpoint mult (n m:nat) : nat :=
  match n with
  | O => 0
  | S p => m + p * m
  end
where "n * m" := (mult n m) : nat_scope.
Hint Resolve (f_equal2 mult): core.
Lemma mult_n_O : forall n:nat, 0 = n * 0.
Proof.
Qed.
Hint Resolve mult_n_O: core.
Lemma mult_n_Sm : forall n m:nat, n * m + n = n * S m.
Proof.
  intros; induction n as [| p H]; simpl in |- *; auto.
  destruct H; rewrite <- plus_n_Sm; apply (f_equal S).
  pattern m at 1 3 in |- *; elim m; simpl in |- *; auto.
Qed.
Hint Resolve mult_n_Sm: core.
Notation mult_0_r_reverse := mult_n_O (only parsing).
Notation mult_succ_r_reverse := mult_n_Sm (only parsing).
(** Truncated subtraction: [m-n] is [0] if [n>=m] *)
Fixpoint minus (n m:nat) : nat :=
  match n, m with
  | O, _ => n
  | S k, O => n
  | S k, S l => k - l
  end
where "n - m" := (minus n m) : nat_scope.
(** Definition of the usual orders, the basic properties of [le] and [lt]
    can be found in files Le and Lt *)
Inductive le (n:nat) : nat -> Prop :=
  | le_n : n <= n
  | le_S : forall m:nat, n <= m -> n <= S m
where "n <= m" := (le n m) : nat_scope.
Hint Constructors le: core.
(*i equivalent to : "Hints Resolve le_n le_S : core." i*)
Definition lt (n m:nat) := S n <= m.
Hint Unfold lt: core.
Infix "<" := lt : nat_scope.
Definition ge (n m:nat) := m <= n.
Hint Unfold ge: core.
Infix ">=" := ge : nat_scope.
Definition gt (n m:nat) := m < n.
Hint Unfold gt: core.
Infix ">" := gt : nat_scope.
Notation "x <= y <= z" := (x <= y /\ y <= z) : nat_scope.
Notation "x <= y < z" := (x <= y /\ y < z) : nat_scope.
Notation "x < y < z" := (x < y /\ y < z) : nat_scope.
Notation "x < y <= z" := (x < y /\ y <= z) : nat_scope.
Theorem le_pred : forall n m, n <= m -> pred n <= pred m.
Proof.
induction 1; auto. destruct m; simpl; auto.
Qed.
Theorem le_S_n : forall n m, S n <= S m -> n <= m.
Proof.
intros n m. exact (le_pred (S n) (S m)).
Qed.
(** Case analysis *)
Theorem nat_case :
 forall (n:nat) (P:nat -> Prop), P 0 -> (forall m:nat, P (S m)) -> P n.
Proof.
  induction n; auto.
Qed.
(** Principle of double induction *)
Theorem nat_double_ind :
 forall R:nat -> nat -> Prop,
   (forall n:nat, R 0 n) ->
   (forall n:nat, R (S n) 0) ->
   (forall n m:nat, R n m -> R (S n) (S m)) -> forall n m:nat, R n m.
Proof.
  induction n; auto.
  destruct m as [| n0]; auto.
Qed.
(** Maximum and minimum : definitions and specifications *)
Fixpoint max n m : nat :=
  match n, m with
    | O, _ => m
    | S n', O => n
    | S n', S m' => S (max n' m')
  end.
Fixpoint min n m : nat :=
  match n, m with
    | O, _ => 0
    | S n', O => 0
    | S n', S m' => S (min n' m')
  end.
Theorem max_l : forall n m : nat, m <= n -> max n m = n.
Proof.
induction n; destruct m; simpl; auto. inversion 1.
intros. apply f_equal. apply IHn. apply le_S_n. trivial.
Qed.
Theorem max_r : forall n m : nat, n <= m -> max n m = m.
Proof.
Qed.
Theorem min_l : forall n m : nat, n <= m -> min n m = n.
Proof.
Qed.
Theorem min_r : forall n m : nat, m <= n -> min n m = m.
Proof.
Qed.
