- To: Tom Prince <tom.prince AT ualberta.net>
- Cc: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Init/Peano.v
- Date: Thu, 19 May 2011 15:15:30 -0400
No, the point is that I'll have to re-write it using hProp instead of Prop,
so I needed the original.
V.
On May 19, 2011, at 3:00 PM, Tom Prince wrote:
> On 2011-05-19, Vladimir Voevodsky wrote:
>> where can I find the source (.v file ) for the basic library e.g.
>> Init/Peano.v ? It does not appear to be in the usual sources.
> I see in an other reply, that you found this file. However, if you
> were asking so that you could include it in your repo, there is no
> need to include anything in the coq stdlib. Anybody wanting to use
> your repo will already have them installed.
> Tom
- Re: [Coq-Club] an update to "Univalent Foundations", Robin Green
Vladimir Voevodsky
- [Coq-Club] Init/Peano.v,
Vladimir Voevodsky
- Re: [Coq-Club] Init/Peano.v, AUGER Cedric
- Re: [Coq-Club] Init/Peano.v, Vladimir Voevodsky
Tom Prince
Vladimir Voevodsky
- <Possible follow-ups>
Bruno Barras
Tom Prince
- Re: [Coq-Club] an update to "Univalent Foundations", Vladimir Voevodsky
Tom Prince
Vladimir Voevodsky
