coq-club - Re: [Coq-Club] A question about unicity of proofs
chronological Thread
  • To: Pierre Casteran <pierre.casteran AT labri.fr>
  • Cc: AUGER Cedric <Cedric.Auger AT lri.fr>, Damien Pous <Damien.Pous AT inrialpes.fr>, coq-club AT inria.fr, Vincent Filou <vincent.filou AT labri.fr>
  • Subject: Re: [Coq-Club] A question about unicity of proofs
  • Date: Fri, 20 May 2011 14:53:59 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:subject:mime-version:content-type:from:in-reply-to:date:cc :content-transfer-encoding:message-id:references:to:x-mailer; b=c3wXng89zvD4baGISCgJxulq7Zt6bQq2EyxlMQpK419KrKsAvpPVuks2YA6RdkQjVB ni+AxXiWp3cxts6l9+RJIWPbzfEklDsvkD9jKzdkOlEHUmrbFtmJ9OmFSlPGd1F043+j qPBUof3zCanvcA8ev9el10p2HmkeJyCQU1lN0=
Hi,
  here's another way to do the axiom-free proof without resorting to natP.
The trick is to use the inversion lemmas which do not require any axioms.
Variable (A:Type).
CoInductive LList :=
  | LNil: LList
  | LCons : A -> LList -> LList.
Inductive Finite : LList -> Prop :=
  |Finite_LNil: Finite LNil
  |Finite_LCons   : forall a l, Finite l-> Finite (LCons a l).
Lemma finite_lnil_inv : forall f : Finite LNil, f = Finite_LNil.
Proof. intros.
  refine (match f as f' in Finite l return
            (match l return Finite l -> Prop with
               | LNil => fun f => f = Finite_LNil
               | _ => fun _ => True end) f'
            with Finite_LNil => eq_refl
              | Finite_LCons a l f => I
          end).
Qed.
Lemma finite_lcons_inv a l : forall f : Finite (LCons a l),
  exists f', f = Finite_LCons a l f'.
Proof. intros.
               | LNil => fun f => True
               | LCons a l => fun f => exists f'', f = Finite_LCons a l f''
end) f'
            with Finite_LNil => I
              | Finite_LCons a l f => ex_intro _ f eq_refl
          end).
Qed.
Lemma finite_l_eq : forall {l} (H H0:Finite l), H = H0.
Proof. fix 2. intros.
  destruct H. rewrite finite_lnil_inv. reflexivity.
  destruct (finite_lcons_inv _ _ H0). rewrite H1. f_equal. apply finite_l_eq.
Qed.
Print Assumptions finite_l_eq.
-- Matthieu
