- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: Damien Pous <Damien.Pous AT inrialpes.fr>, coq-club AT inria.fr, Vincent Filou <vincent.filou AT labri.fr>
- Subject: Re: [Coq-Club] A question about unicity of proofs
- Date: Fri, 20 May 2011 11:20:34 +0200
Hello, Cedric, Damien and Thorsten,
Thank you for your answers.
I could prove the decidability of equality on finite lists (assuming this property on A).
Lemma LList_eq_dec: forall h :LList, Finite h -> forall k, Finite k -> {h=k}+{h<>k}.
Then I try to use eq_dep_eq_dec, but it requires the decidability of equality
over the considered type Llist A.
- Is there any version of this theorem allowing me to apply Llist_eq_dec instead
of decidability of equality on LList A ? In Logic.Eqdep_dec ? In the litterature ?
Pierre
Le 20/05/2011 09:49, AUGER Cedric a écrit :
Le Fri, 20 May 2011 09:41:35 +0200,
Damien
Pous<Damien.Pous AT inrialpes.fr>
a écrit :
Bonjour Pierre,I got this proof which always require an axiom, but simply using
Here is a proof assuming that equality is decidable on streams (which
is certainly not the case).
This is because I use the lemma eq_dep_eq_dec to transform an eq_dep
into a plain eq.
Would a similar lemma about eq_dep hold assuming proof irrelevance on
A rather than decidability on LList A ?
Best,
Damien
eq_dep_eq (what is the command to know all the axioms a definition
depends on?)
Variable (A:Type).
CoInductive LList :=
| LNil: LList
| LCons : A -> LList -> LList.
Inductive Finite : LList -> Prop :=
|Finite_LNil: Finite LNil
|Finite_LCons : forall a l, Finite l-> Finite (LCons a l).
Require Import Eqdep.
Goal forall l (H H0:Finite l), H=H0.
(* as I guess it won't be proved without dependant equality,
I change the goal to make it provable using an axiom *)
intros l H H0; apply eq_dep_eq.
(* OK, now we can proceed by first "unrelating" H and H0 *)
generalize (eq_refl l); revert H0; generalize l at 1 3 5.
(* OK, now the induction can start;
as induction doesn't work here, I use fix *)
revert l H; fix 2; intros _ [] _ [] Heq.
(*-> LNil vs LNil*)
split.
(*-> LNil vs LCons*)
discriminate.
(*-> LCons vs LNil*)
discriminate.
(*-> LCons vs LCons*)
(* as always, fist thing to do is get rid of the recursive call *)
generalize (Unnamed_thm l0 f l2 f0); clear -Heq.
(* now we eliminate our equality *)
revert f; inversion_clear Heq; clear.
(* we simplify our recursive call *)
intros; generalize (H (eq_refl _)); clear.
(* we prepare our last equality for elimination *)
revert f0; generalize l2 at 1 3 6 7; intros.
(* we eliminate our equality *)
destruct H.
(* we conclude *)
split.
Qed.
Set Implicit Arguments.
Require Import Eqdep Eqdep_dec.
Section s.
Variable (A:Type).
| LNil: LList
|Finite_LCons : forall a l, Finite l -> Finite (LCons a l).
Notation "H == K" := (eq_dep _ Finite _ H _ K) (at level 80).
Fixpoint dep h (H: Finite h): forall k (K: Finite k), h = k -> H == K.
destruct H; destruct K.
reflexivity.
discriminate.
discriminate.
intro E. injection E. intros E1 E2.
rewrite (dep _ H _ K E1). subst. reflexivity.
Defined.
Goal forall l (H K:Finite l), H==K.
Proof.
intros. apply dep. reflexivity.
Qed.
Axiom LList_dec: forall h k: LList, {h=k}+{h<>k}.
Goal forall l (H K:Finite l), H=K.
Proof.
intros. apply Eqdep_dec.eq_dep_eq_dec.
apply LList_dec.
Qed.
2011/5/20 Pierre
Casteran<pierre.casteran AT labri.fr>:
Hello,
Let us consider a type of finite or infinite lists :
Variable (A:Type).
| LNil: LList
Is it possible to prove unicity of proofs of Finite ?
Goal forall l (H H0:Finite l), H=H0 ?
Pierre
- [Coq-Club] A question about unicity of proofs, Pierre Casteran
- Re: [Coq-Club] A question about unicity of proofs,
Damien Pous
AUGER Cedric
- Re: [Coq-Club] A question about unicity of proofs, Pierre Casteran
- Re: [Coq-Club] A question about unicity of proofs, AUGER Cedric
AUGER Cedric
Pierre Casteran
- Re: [Coq-Club] A question about unicity of proofs, Matthieu Sozeau
Pierre Casteran
AUGER Cedric
Damien Pous
