- To: coq-club AT inria.fr
- Subject: [Coq-Club] strange behaviour while defining inductive types.
- Date: Thu, 26 May 2011 10:41:58 +0200
Hi all, I don't understand why the first definition is accepted and not
the second one.
Inductive bool_comp (b: bool): bool -> Prop :=
| Opp: forall q, (if b
then match q with true => False | false => True end
else match q with true => True | false => False end)
-> bool_comp b q.
Print bool_comp.
Inductive bool_comp2 (b: bool): bool -> Prop :=
| Opp2: forall q, (match b return Prop with
| true => match q return Prop with true => False |
false => True end | false => match q return Prop with true => True |
false => False end end) -> bool_comp2 b q.
- [Coq-Club] strange behaviour while defining inductive types., AUGER Cedric
- Re: [Coq-Club] strange behaviour while defining inductive types., AUGER Cedric
- Re: [Coq-Club] strange behaviour while defining inductive types., Pierre Courtieu
- Re: [Coq-Club] strange behaviour while defining inductive types., Hugo Herbelin
