- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] strange behaviour while defining inductive types.
- Date: Thu, 26 May 2011 10:54:39 +0200
Le Thu, 26 May 2011 10:41:58 +0200,
AUGER Cedric
a écrit :
> Hi all, I don't understand why the first definition is accepted and
> not the second one.
> Inductive bool_comp (b: bool): bool -> Prop :=
> | Opp: forall q, (if b
> then match q with true => False | false => True end
> else match q with true => True | false => False end)
> -> bool_comp b q.
> Print bool_comp.
> Inductive bool_comp2 (b: bool): bool -> Prop :=
> | Opp2: forall q, (match b return Prop with
> | true => match q return Prop with true => False |
> false => True end | false => match q return Prop with true => True |
> false => False end end) -> bool_comp2 b q.
And by the way, in the second case, I really don't understand what
could be the reason to refuse it, as the result type is outside of the
result type, since you can make a definition from the "match ... end",
and then use it inside the inductive.
(I could understand to refuse
"Inductive pred (d: nat): nat -> Prop :=
| Pred: match d with O => pred d O | S n => pred d n end".
but it is noth the case here.)
- [Coq-Club] strange behaviour while defining inductive types., AUGER Cedric
- Re: [Coq-Club] strange behaviour while defining inductive types., AUGER Cedric
- Re: [Coq-Club] strange behaviour while defining inductive types., Pierre Courtieu
- Re: [Coq-Club] strange behaviour while defining inductive types., Hugo Herbelin
