coq-club - Re: [Coq-Club] applying a function definition
chronological Thread
  • To: Guillaume Brunerie <guillaume.brunerie AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] applying a function definition
  • Date: Sat, 28 May 2011 12:14:41 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=subject:mime-version:content-type:from:in-reply-to:date:cc :message-id:references:to:x-mailer; b=Mm9PnAp9nCoPUw+TAK4CMjLRRnCq703C2ayXzN+nON9jEhozgM+qsUchPQy05e1cWr B+6smY5VHjTUF5+B4YA7NmyEqI/HG0lolMFF9R64nnCemb8a6XkkvYXKH9+X+vRpl2H2 +dqCeRBKt/idogFY3X0J33bJLgGLWNs5Y4ojo=
Thanks - that explains the magic indeed! After adding a matching successor function and showing that sx <> e, I have:
Inductive B : Set :=
|  e : B
|  o : B -> B
|  i : B -> B.
Delimit Scope b_scope with B.
Bind Scope b_scope with B.
Arguments Scope o [b_scope].
Arguments Scope i [b_scope].
Fixpoint p (x : B) : B :=
  match x with
  | e => e (* this should rather be undefined or an exception *)
  | o e => e
  | o a => i (p a)
  | i a => o a
  end.
Fixpoint s (x : B) : B :=
  match x with
  | e => o e
  | o a => i a
  | i a => o (s a)
  end.
Lemma po_ip : forall n:B, n<>e -> p (o n) = i (p n).
Proof.
  intros n H.
  simpl.
  case_eq n; firstorder.
Qed.
Lemma s_discr : forall x:B, x <> s x.
Proof.
  destruct x; discriminate.
Qed.
Lemma pos_ips : forall x:B, p (o (s x)) = i (p (s x)).
Proof.
intros.
case_eq x;firstorder.
Qed.
Lemma psi_os : forall n:B, p (s (i n)) = p (o (s n)).
Proof.
intro n; auto.
Qed.
Eval compute in p (p (s (s e))).
Lemma sp_inv : forall n:B, p (s n) = n.
Proof.
intros.
case_eq n;firstorder.
Show.
(* which gives:
  n : B
  b : B
  H : n = i b
   p (s (i b)) = i b
I would like Coq to reason along the following equations:
    p (s (i b)) = p (o (s b)) = i (p (s b)) = i b
where I want to use, as an inductive hypothesis, that p (s b) = b holds.
I tried "apply psi_os" (that I just proved) but it seems to want both sides
of an equation - is there any way to make it just rewrite p (s (i b)) as
p (o (s b)) according to Lemma psi_os?
> apply psi_os.
Error: Impossible to unify "p (s (i ?55)) = p (o (s ?55))" with
 "p (s (i b)) = i b".
Paul
On May 28, 2011, at 10:52 AM, Guillaume Brunerie wrote:
2011/5/28 Paul Tarau <paul.tarau AT gmail.com>
Thanks a lot, the following did it!
Proof.
intros n H.
simpl.
Show.
case_eq n.
firstorder.
firstorder.
intros.
firstorder.
Qed.
You can do even shorter with :
Proof.
  intros n H.
  simpl.
Qed.
The semicolon asks Coq to apply the tactic 'firstorder' to every new subgoal.
I am still puzzled why after simpl I get:
  n : B
  H : n <> e
   match n with
   | e => e
   | o _ => i (p n)
   | i _ => i (p n)
   end = i (p n)
where the underscores indicate that Coq is ignoring or forgetting the actual argument - this does not seem equivalent with the definition of p. Impressed that magic works:-), but is there anything that could make the proof obtained by the sequence of tactics somewhat human readable - for instance I would be curious to see what firstorder did "under the hood".
'firstorder' hasn’t done any magic, the magic comes from 'simpl'.
When Coq is simplifiying the _expression_ 'p (o n)',
If n = e, then p (o e) = e by definition.
If n = o a, then p (o n) = p (o (o a)) = i (p (o a)) = i (p n)
If n = i a, then p (o n) = p (o (i a)) = i (p (i a)) = i (p n)
In the two latter cases, the result does not depend on a (the underscore), it depends only on n.
And what is left to 'firstorder' to prove is that :
If n = e, something, but n <> e so this is true
If n is of the form (o a) or (i a), then i (p n) = i (p n) which is true.
Guillaume
