- To: coq-club AT inria.fr
- Subject: [Coq-Club] Abuse of coercions gives weird results in coqtop.
- Date: Sun, 29 May 2011 16:14:45 +0300
- Header: best read with a sniffer
$ coqtop
Welcome to Coq 8.2pl1 (February 2010)
Coq < Unset Printing All.
Coq < Require Import fib13.
Ambiguous paths:
[fib13.expr2] : fib13.type >-> Sortclass
Coq < Check a1.
a1
: FUCKMS
Coq < Check a2.
a2
: FUCKMS -> False
Coq < Print Assumptions a1.
Closed under the global context
Coq < Print Assumptions a2.
Coq < Print False.
Inductive False : Prop :=
I have problem getting a real contradiction though.
Attached is source code.
joro
(* Part of this file is from
http://www-verimag.imag.fr/~boulme/SIMPLY_TYPED_LAMBDA_MU/SimplyTypedLambdaMu.v
(** * Mixed Embedding of Simply Typed Lambda-Mu Calculus.
This file is an introduction to the simply typed version of
Parigot's calculus. It implements Curry-Howard paradigm in
classical propositional logic.
I prove here that the logic is consistent.
I also give a weak result on the completeness of the proof system.
I emulate in Coq an interpreter of this lambda-calculus
(I give small examples of reduction).
Technically, I use a higher-order abstract syntax technique to
avoid the tedious handling of binders.
Set Implicit Arguments.
(** Preliminary: negation on Type *)
Definition neg (A: Type) := A -> False.
(** * Syntax of types (e.g. of classical propositions).
We consider here Coq propositions as atomic formulas.
Inductive type: Type :=
| ATOM: Prop -> type
| ARROW: type -> type -> type.
Infix "==>" := ARROW (at level 80, right associativity).
(** * Derived types *)
Definition FUCKMS: type := ATOM False.
Definition TRUE: type := ATOM True.
Definition NOT (T: type): type
:= T ==> FUCKMS.
Definition OR (A B: type): type
:= (NOT A) ==> B.
Definition AND (A B: type): type
:= NOT (A ==> (NOT B)).
(** * Syntax of Terms (e.g. of proofs) *)
Section TERMS.
(** I give the abstract syntax of terms before to explain there
informal meaning (see "logical intuitions" below). The calculus is a
usual lambda-calculus extend with a continuation-handling mechanism.
- In order to avoid the encoding of variable substitution,
a bound variable is represented directly as a Coq function
(see [LAMBDA] and [MU] binders).
- Terms are parameterized by the (meta)type of variables.
- Here, we represent only "well-typed" terms (typing of lambda-mu
calculus is emulated by Coq typing).
- The meta-type of variables is itself parameterized by a type
(the type of term abstracted by the given variable).
- In this language, there are two syntactic categories of variable:
-- [vV] (variable for "values") introduced by [LAMBDA].
-- [vC] (variable for "continuations") introduced by [MU].
Variable vV: type -> Type.
Variable vC: type -> Type.
Inductive term: type -> Type :=
(** usual constants: we embed here double negation of Coq proofs *)
| CTE (P:Prop): neg (neg P) -> (term (ATOM P))
(** usual variables *)
| VAR (A:type): (vV A) -> (term A)
(** usual lambda-abstraction *)
| LAMBDA (A B:type): ((vV A) -> (term B)) -> (term (A ==> B))
(** usual application *)
| APP (A B:type): (term (A ==> B)) -> (term A) -> (term B)
(** application of a term to a continuation (branch to this continuation) *)
| BRA (A:type): (vC A) -> (term A) -> (term FUCKMS)
(** abstraction of a continuation *)
| MU (A:type): ((vC A) -> (term FUCKMS)) -> (term A)
- [Coq-Club] Abuse of coercions gives weird results in coqtop., Georgi Guninski
- Re: [Coq-Club] Abuse of coercions gives weird results in coqtop.,
Georgi Guninski
- Re: [Coq-Club] Abuse of coercions gives weird results in coqtop., Georgi Guninski
Georgi Guninski
- Re: [Coq-Club] Abuse of coercions gives weird results in coqtop., Adam Chlipala
Brandon Moore
Georgi Guninski
