- To: Brandon Moore <brandon_m_moore AT yahoo.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Abuse of coercions gives weird results in coqtop.
- Date: Mon, 30 May 2011 18:22:03 +0300
- Header: best read with a sniffer
On Mon, May 30, 2011 at 07:51:47AM -0700, Brandon Moore wrote:
> I don't see the point. If you are worried about people playing syntactic
> games,
> examine the statement with notations and coercions turned off. You
> might as well say you have a "contradiction" because you can write
> Notation "'Truth'" := False.
> Lemma contradiction : Truth -> False. auto. Qed.
> "t" isn't a sort, so it's obvious your goal won't typecheck without
> coercions. Displaying coercions, you have
> exists a : t, exp2 a -> False.
> We see exp2 = (fun _ => False), so this should be equivalent to
> exists a : t, (fun _ => False) a -> False.
> Unfolding exp2 gives
> ex _ (fun _ : True => False -> False).
> And there's nothing wrong with being able to prove that.
> Brandon
i asked how to check for cheating proofs.
Bruno (appears a coq developer) replied:
https://sympa-roc.inria.fr/wws/arc/coq-club/2011-05/msg00101.html?checked_cas=2
how a client should check a Coq proof for cheating?
If I were the client I would disable all customized notations with
Unset Printing All.
^ Bruno wrote this.
so i follow his advice:
Coq < Require Import b.
Ambiguous paths:
[b.expr2] : b.type >-> Sortclass
Coq < Unset Printing All.
Coq < Check a1.
a1
: FUCKMS
Coq < Check a2.
a2
: FUCKMS -> False
all of a sudden, coqtop doesn't see a contradiction, possibly due to
what coq fanboys call "Anomaly" in your source.
the error message coqtop gives is borderline insane "X is not X" (or sthg
very close to this).
which parts of coq should i trust?
- [Coq-Club] Abuse of coercions gives weird results in coqtop., Georgi Guninski
- Re: [Coq-Club] Abuse of coercions gives weird results in coqtop.,
Georgi Guninski
- Re: [Coq-Club] Abuse of coercions gives weird results in coqtop., Georgi Guninski
Georgi Guninski
- Re: [Coq-Club] Abuse of coercions gives weird results in coqtop., Adam Chlipala
Brandon Moore
Georgi Guninski
