- To: Georgi Guninski <guninski AT guninski.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Abuse of coercions gives weird results in coqtop.
- Date: Mon, 30 May 2011 11:17:27 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Reply-To:Subject:To:Cc:In-Reply-To:MIME-Version:Content-Type:Content-Transfer-Encoding; b=JNughtmeen507uth8EtMEFOC4GuFpZGAFu5LE9QkMxurLzuu6Mj13UUEKrr3/oq8vME4O9TkLDu/Ux8UjViJm+MMH/os+QIKZE7jYRUVljfwCcwS32i5lAjXVJdy1xfD9ksSbNqI01zK4iEdMdgGSYJ/OUXWyA58I/3haDqrvcI=;
> From: Georgi Guninski
>Â <guninski AT guninski.com>
> Sent: Monday, May 30, 2011 10:22 AM
> i asked how to check for cheating proofs.
> Bruno (appears a coq developer) replied:
> https://sympa-roc.inria.fr/wws/arc/coq-club/2011-05/msg00101.html?checked_cas=2
> how a client should check a Coq proof for cheating?
> If I were the client I would disable all customized notations with
> Unset Printing All.
> ^ Bruno wrote this.
> so i follow his advice:
Oh, he actually had the advice backwards!
It's "Set Printing All" that turns off notations, and starts showing
all coercions, implicit arguments, and other things that may
normally be hidden. ("Unset" goes the other way, and makes things
short but possibly misleading again)
http://coq.inria.fr/refman/Reference-Manual004.html#toc23
You might also set "Set Printing Universes".
Brandon
- Re: [Coq-Club] Abuse of coercions gives weird results in coqtop., (continued)
Georgi Guninski
- Re: [Coq-Club] Abuse of coercions gives weird results in coqtop., Georgi Guninski
Georgi Guninski
- Re: [Coq-Club] Abuse of coercions gives weird results in coqtop., Adam Chlipala
Brandon Moore
Georgi Guninski
- Re: [Coq-Club] Abuse of coercions gives weird results in coqtop., Brandon Moore
Georgi Guninski
Georgi Guninski
