coq-club - Re: [Coq-Club] "Transparent" module types, ala O'Caml?
chronological Thread
  • To: frank maltman <frank.maltman AT googlemail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] "Transparent" module types, ala O'Caml?
  • Date: Sun, 5 Jun 2011 16:45:58 -0400
Hi Frank,
changing
> Module Monad_Option : Base.
to
> Module Monad_Option <: Base.
does the trick. The former masks the computational content of the
module, while the latter just asks Coq to check that the signature of
Monad_Option is a subtype of the signature Base.
Regards,
-- Mathieu
On Sun, Jun 05, 2011 at 08:33:10PM +0000, frank maltman wrote:
> Hello.
> I've written a simple monad module type and an implementation using 'option'
> but have come up against an issue when trying to actually use the module:
> Module Type Base.
>   Parameter M : Type -> Type.
>   Parameter monad_bind   : forall {A B : Type}, M A -> (A -> M B) -> M B.
>   Parameter monad_return : forall {A : Type}, A -> M A.
>   Parameter monad_left_identity : forall (A B : Type) (x : A) (f : A -> M
> B),
>     monad_bind (monad_return x) f = f x.
>   Parameter monad_right_identity : forall (A : Type) (m : M A),
>     monad_bind m monad_return = m.
>   Parameter monad_associativity : forall (A B C : Type) (f : A -> M B) (g :
> B -> M C) (m : M A),
>     monad_bind (monad_bind m f) g = monad_bind m (fun z => monad_bind (f z)
> g).
> End Base.
>   Definition M := option.
>   Definition monad_bind {A B : Type} (m : option A) (f : A -> option B) :
> option B :=
>     match m with
>       | Some x => f x
>       | None   => None
>     end.
>   Definition monad_return {A : Type} (x : A) : option A := Some x.
>   Definition monad_left_identity : forall (A B : Type) (x : A) (f : A ->
> option B),
>   Proof.
>     intros A B x f.
>     reflexivity.
>   Defined.
>   Definition monad_right_identity : forall (A : Type) (m : option A),
>   Proof.
>     intros A m.
>     destruct m as [|m'].
>     reflexivity.
>     reflexivity.
>   Defined.
>   Definition monad_associativity : forall {A B C : Type} (f : A -> option
> B) (g : B -> option C) (m : option A),
> g).
>   Proof.
>     intros A B C f g m.
>     reflexivity.
>     reflexivity.
>   Defined.
> End Monad_Option.
> > Check Monad_Option.monad_bind (Some 1).
> Error: The term "Some 1" has type "option nat"
>  while it is expected to have type "Monad_Option.M ?68".
> I believe the problem is that Monad_Option.M is considered a distinct type
> from 'option'. I think I may need to add something in the same manner as
> I would in O'Caml (unless I'm mistaken):
> module Base : Monad.Base with type 'a monad = 'a option = ...
> Does coq have something similar (or am I looking at a different problem
> entirely)?
