- From: frank maltman <frank.maltman AT googlemail.com>
- To: <coq-club AT inria.fr>
- Subject: [Coq-Club] "Transparent" module types, ala O'Caml?
- Date: Sun, 5 Jun 2011 20:33:10 +0000
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=date:from:to:subject:message-id:x-mailer:mime-version:content-type :content-transfer-encoding; b=ZEAfOclv1G+8ty7SXBgXifgamfOiXm42zHqDOUyidPcsp9IAL/briTBgo9RTdgJfN4 h7PDu2faxK0cLj7owgr+pGo3/OVYh3HfGq7ErmW+kc+EEUGveswCvIBLoD0lBKFCv+e9 MmAUx12WfhvnZweXvHlp6Mw1RzwV84YAfkk/U=
Hello.
I've written a simple monad module type and an implementation using 'option'
but have come up against an issue when trying to actually use the module:
Module Type Base.
Parameter M : Type -> Type.
Parameter monad_bind : forall {A B : Type}, M A -> (A -> M B) -> M B.
Parameter monad_return : forall {A : Type}, A -> M A.
Parameter monad_left_identity : forall (A B : Type) (x : A) (f : A -> M B),
monad_bind (monad_return x) f = f x.
Parameter monad_right_identity : forall (A : Type) (m : M A),
monad_bind m monad_return = m.
Parameter monad_associativity : forall (A B C : Type) (f : A -> M B) (g : B
-> M C) (m : M A),
monad_bind (monad_bind m f) g = monad_bind m (fun z => monad_bind (f z)
g).
End Base.
Module Monad_Option : Base.
Definition M := option.
Definition monad_bind {A B : Type} (m : option A) (f : A -> option B) :
option B :=
match m with
| Some x => f x
| None => None
end.
Definition monad_return {A : Type} (x : A) : option A := Some x.
Definition monad_left_identity : forall (A B : Type) (x : A) (f : A ->
option B),
Proof.
intros A B x f.
reflexivity.
Defined.
Definition monad_right_identity : forall (A : Type) (m : option A),
Proof.
intros A m.
destruct m as [|m'].
reflexivity.
reflexivity.
Defined.
Definition monad_associativity : forall {A B C : Type} (f : A -> option B)
(g : B -> option C) (m : option A),
g).
Proof.
intros A B C f g m.
reflexivity.
reflexivity.
Defined.
End Monad_Option.
> Check Monad_Option.monad_bind (Some 1).
Error: The term "Some 1" has type "option nat"
while it is expected to have type "Monad_Option.M ?68".
I believe the problem is that Monad_Option.M is considered a distinct type
from 'option'. I think I may need to add something in the same manner as
I would in O'Caml (unless I'm mistaken):
module Base : Monad.Base with type 'a monad = 'a option = ...
Does coq have something similar (or am I looking at a different problem
entirely)?
- [Coq-Club] "Transparent" module types, ala O'Caml?, frank maltman
- Re: [Coq-Club] "Transparent" module types, ala O'Caml?,
Mathieu Boespflug
- Re: [Coq-Club] "Transparent" module types, ala O'Caml?, frank maltman
AUGER Cedric
- Re: [Coq-Club] "Transparent" module types, ala O'Caml?, Damien Pous
Mathieu Boespflug
