- To: coq-club AT inria.fr
- Subject: [Coq-Club] Trouble declaring a ring (or, how to tell ring b && b = b)
- Date: Tue, 7 Jun 2011 22:12:57 +0200
I've found ring helpful for solving equations between boolean conjunctions.
It would be nice if it would simplify repeated terms.
I was thinking I could do this be registering the trivial "power" function b ^
n = b || (n > 0).
In preparation for messing with power_tac, I tried to make my own boolean type
and declare a ring over it. All the proofs and the Add Ring declaration go
through
without trouble, but attempting to use ring afterwards produces a large error
message.
Require Import Ring.
Inductive bool2 : Set := t | f.
Definition xor2 a b :=
match a, b with
| t, t => f
| t, f => t
| f, t => t
| f, f => f
end.
Definition and2 a b :=
match a with
| t => b
| f => f
end.
Definition eq2 a b :=
match a, b with
| t, t => true
| t, f => false
| f, t => false
| f, f => true
end.
Lemma eq2_prop a b : eq2 a b = true -> a = b.
Proof. destruct a; destruct b; simpl; congruence. Qed.
Definition bool2_pow (b : bool2) (pow : BinNat.N) : bool2 :=
match pow with
| BinNat.N0 => t
| BinNat.Npos _ => b
end.
Lemma and2_idem (b : bool2) : and2 b b = b.
destruct b; reflexivity. Qed.
Lemma bool_pow_pow : Ring_theory.power_theory t and2 (@eq _) (@id _)
bool2_pow.
constructor. intros. destruct n; simpl. reflexivity.
pose proof (and2_idem r). induction p; simpl; congruence.
Qed.
Ltac ignore_bool2_powers e := InitialRing.NotConstant.
Lemma bool2_ring : ring_theory f t xor2 and2 xor2 (@id _) (@eq _).
Proof.
constructor; repeat (intros b; destruct b; try reflexivity).
Qed.
Add Ring bring : bool2_ring (decidable eq2_prop).
(* power_tac bool_pow_pow [ignore_bool2_powers]). *)
Lemma test (b : bool2) : and2 b b = b.
ring.
This produces an error:
In nested Ltac calls to "F" (bound to PackRing ltac:Ring_gen), "PackRing",
"F" (bound to
fun RNG lH rl =>
let lemma := get_NormLemma RNG in
get_Pre RNG (); Ring RNG (lemma ring_subst_niter) lH), "Ring",
"OnEquation", "f" (bound to
fun lhs rhs =>
let mkFV := get_RingFV RNG in
let mkPol := get_RingMeta RNG in
let mkHyp := get_RingHypTac RNG in
let fv := FV_hypo_tac mkFV ltac:(get_Eq RNG) lH in
let fv := mkFV lhs fv in
let fv := mkFV rhs fv in
ListTactics.check_fv fv;
(let pe1 := mkPol lhs fv in
let pe2 := mkPol rhs fv in
let lpe := mkHyp fv lH in
let vlpe := fresh "hyp_list" in
let vfv := fresh "fv_list" in
pose (vlpe := lpe); pose (vfv := fv);
apply (lemma vfv vlpe pe1 pe2) || fail
"typing error while applying ring";
[ (let prh := proofHyp_tac lH in
exact prh) || idtac "can not automatically proof hypothesis :"; idtac
" maybe a left member of a hypothesis is not a monomial"
| vm_compute; exact (eq_refl true) || fail "not a valid ring equation"
"mkFV" (bound to
fun t fv =>
let rec TFV t fv :=
(let f :=
(match Cst t with
| NotConstant =>
match t with
| add ?t1 ?t2 => fun _ => TFV t2 ltac:(TFV t1 fv)
| mul ?t1 ?t2 => fun _ => TFV t2 ltac:(TFV t1 fv)
| sub ?t1 ?t2 => fun _ => TFV t2 ltac:(TFV t1 fv)
| opp ?t1 => fun _ => TFV t1 fv
| pow ?t1 ?n =>
match CstPow n with
| NotConstant => fun _ => ListTactics.AddFvTail t fv
| _ => fun _ => TFV t1 fv
end
| _ => fun _ => ListTactics.AddFvTail t fv
end
| _ => fun _ => fv
end) in
f ()) in
TFV t fv), "TFV" (bound to
fun t fv =>
let f :=
(match Cst t with
| NotConstant =>
match t with
| pow ?t1 ?n =>
match CstPow n with
end
end
| _ => fun _ => fv
end) in
f ()) and "Cst" (bound to fun t => match t with
| rO => cO
| rI => cI
end), last call failed.
Error: No matching clauses for match.
- [Coq-Club] Trouble declaring a ring (or, how to tell ring b && b = b), brandon_m_moore
