coq-club - Re: [Coq-Club] Confusing error rewriting by impl with result in propositional with parameter
chronological Thread
  • To: Matthieu Sozeau <mattam AT mattam.org>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Confusing error rewriting by impl with result in propositional with parameter
  • Date: Tue, 7 Jun 2011 13:02:33 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Reply-To:Subject:To:Cc:In-Reply-To:MIME-Version:Content-Type:Content-Transfer-Encoding; b=Dc6scAoVq/Xy9nMZeJ+lUQSJUtVE+awMrUw40tAIsINJzY/syWx8QX0w7zeHaR2zQ7oU1+yQjFhmxSMSkHsJS0YLo3D3ikMPl3F5BYcOG4n+5I/EvKtWE7OCX9pJCrEUDmc3KSFQt9C0yyTsz6KizYoaYR/bW3ZEAb6HLngYHog=;
----- Original Message -----
> From: Matthieu Sozeau
> To:
> brandon_m_moore AT yahoo.com
> Cc:
> Sent: Tuesday, June 7, 2011 7:09 AM
> Le 2 juin 2011 à 23:04,
>  a écrit :
>>  I'm trying to use setoid rewriting over impl to simplify hypotheses.
>>  It usually works fine, but if the conclusion of the implication is
>>  an equality or similarly defined inductive type, there are problems.
>>  rewriting in * |- always seems to fail, by encountering a fatal error
>>  when deciding whether the rule can be used to rewrite in a type
>>  like Z in a hypothesis like (p : Z).
> Hello Brandon,
>   indeed the error should not be fatal for a [rewrite in * |-], it
> was an overlook, now fixed in the trunk. One unpractical workaround
> would be to make "impl" opaque before the rewrite (using [Opaque
> impl]).
Thanks for the quick fix.
What is wrong with making impl opaque? It seems to work
in small examples.
> Another one would be to use an inductive definition like:
> Record implication (A B : Prop) : Prop := mkImpl { impl_proof : A -> B }.
> Instance: subrelation implication impl.
> Proof. intros x y [H]. assumption. Qed.
> Parameter breaks : forall a b,  implication (Zeq_bool a b = true) (a = b).
> Lemma examples p q : Zeq_bool p q = true -> True.
> Proof. intro H. rewrite breaks in *. constructor. Qed.
I'm already proving all the lemmas I want to rewrite by,
so it should be easy to switch to this.
Brandon
