- From: Pierre Boutillier <pierre.boutillier AT pps.jussieu.fr>
- To: Jean-Jacques Levy <jean-jacques.levy AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] problem with plugin and 32-bit precompiled Mac version
- Date: Fri, 17 Jun 2011 17:13:52 +0200
Hi,
There is a mac format for both 32 and 64 bits but ocamlc doesn't give way to use it. Neither directly but nor an easy way to build native code for one architecture on an other !
I know that it exists a cross compiler for windows so stuff can be done but I don't want to do neither the requested hack nor the build system to use it !
More over since ocaml package for mac is 32bits, I'll provide a package for "packages users" i e a 32b one ...
Anyway, if you need a independant 64b package right now, there is one here : http://www.pps.jussieu.fr/~pboutill/coq-night/coq-trunk-x86_64-2011-06-17.dmg
Pierre
Le 17 juin 11 à 10:35, Jean-Jacques Levy a écrit :
Hello crowd!
problem with coq-8.3pl2-macosx.dmg with following plugin:
coqc -q -R theories Ssreflect -R src Ssreflect theories/ssreflect
File "/Users/levy/Downloads/ssreflect-1.3pl1/theories/ssreflect.v", line 5, characters 0-30:
Error: error loading shared library: dlopen(/Users/levy/Downloads/ ssreflect-1.3pl1/src/ssreflect.cmxs, 138): no suitable image found. Did find:
/Users/levy/Downloads/ssreflect-1.3pl1/src/ssreflect.cmxs: mach-o, but wrong architecture
make[1]: *** [theories/ssreflect.vo] Error 1
Disk image compiled with 32-bit option, but Ssreflect plugin is compiled with 64-bit. There is this Mac format for having dual formats 32+64. I think it would be preferable to distribute the dual version. Moreover the standard on Mac will evolve to 64-bit.
Best to all, -JJ-
Pierre Boutillier
- [Coq-Club] problem with plugin and 32-bit precompiled Mac version, Jean-Jacques Levy
- Re: [Coq-Club] problem with plugin and 32-bit precompiled Mac version, Xavier Leroy
- Message not available
- Re: [Coq-Club] problem with plugin and 32-bit precompiled Mac version, Jean-Jacques Levy
- <Possible follow-ups>
- Re: [Coq-Club] problem with plugin and 32-bit precompiled Mac version, Pierre Boutillier
