- From: Jean-Jacques Levy <jean-jacques.levy AT inria.fr>
- To: Xavier Leroy <Xavier.Leroy AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] problem with plugin and 32-bit precompiled Mac version
- Date: Fri, 17 Jun 2011 18:03:32 +0200
Le 17 juin 2011 à 17:40, Xavier Leroy a écrit :
> Hi Jean-Jacques,
>> problem with coq-8.3pl2-macosx.dmg with following plugin:
>> Disk image compiled with 32-bit option, but Ssreflect plugin is
> compiled with 64-bit. There is this Mac format for having dual
> formats 32+64. I think it would be preferable to distribute the dual
> version. Moreover the standard on Mac will evolve to 64-bit.
> Indeed: since Mac OS 10.6 (mid-2009), 64-bit mode is the default
> option, and it takes quite a bit of hacking to even get OCaml to
> compile in 32 bits on Mac OS 10.6. To make things worse, Apple
> changed their linker around the same time that 10.6 came out, in ways
> that break OCaml's dynamic loading of shared libraries. So, your
> chances to load a Coq plugin in a 32-bit MacOS version of Coq are
> exactly zero.
> However, it's easy to compile Coq from sources on a Mac. Just use
> Macports or Homebrew to install ocaml, camlp5 and lablgtk2
> automatically. Then, Coq's sources compile like a charm, coqide
> included.
that's what I did, but from standard Coq bundle, since I could not compile
Coq 8.3pl2 from Macports.
Seems only 8.2 is available. -JJ-
> Cheers,
> - Xavier
- [Coq-Club] problem with plugin and 32-bit precompiled Mac version, Jean-Jacques Levy
- Re: [Coq-Club] problem with plugin and 32-bit precompiled Mac version, Xavier Leroy
- Message not available
- Re: [Coq-Club] problem with plugin and 32-bit precompiled Mac version, Jean-Jacques Levy
- <Possible follow-ups>
- Re: [Coq-Club] problem with plugin and 32-bit precompiled Mac version, Pierre Boutillier
