coq-club - Re: [Coq-Club] question about a simple arithmetic theorem
chronological Thread
  • From: Leonardo Rodriguez <leonardomatiasrodriguez AT gmail.com>
  • To: Adam Chlipala <adam AT chlipala.net>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] question about a simple arithmetic theorem
  • Date: Wed, 22 Jun 2011 22:09:26 -0300
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=HiuHkHkW3SsnphArSgINR/CwroRSOcAa/d6mFjR2JEaDHRpx5fM8WO/jcDFAys6gGw ABXRYEBJLi9ezRBAoLX0MP+WIGL4m5WAschf+DhGMeo9WbYnlS0nFVJVc1vPs7+Nz7mM 6SLaQD1NmhyUV7iPGkN3/05cjKle0AZqM8ZAk=
i'm glad for your answer to my first post,   because i'm reading your book about program certification . I hope understand the magic of omega and "crush" tactic in a near future. Your solution with the "replace" tactic was interesting too. Thank you.
2011/6/22 Adam Chlipala <adam AT chlipala.net>
leonardomatiasrodriguez@gmail.com wrote:
I'm just learning Coq, and i'm proving a simple theorem:
Theorem le_minus_minus : forall n m , n<= m ->  m - (m - n) = n.
My idea is to replace the first occurrence of "m" in "m - (m - n)"  by "n + (m
- n)" using
le_plus_minus
     : forall n m : nat, n<= m ->  m = n + (m - n)
and then prove another lemma
      forall n p : nat,  (n+p) - p = n.
to conclude ( n + (m - n) ) - (m - n) = n.
I see you got an answer to your question, but I'd like to point out another tactic that may make your life easier in the future.  The [rewrite] syntax, suggested by Evgeny and used in your posted solution, requires you to keep track of the argument orders of various lemmas.  By using the [replace] tactic instead, you can avoid that need.  Here's an alternate script using [replace] (see the manual for documentation of unfamiliar tactics):
Goal forall n m , n <= m -> m - (m - n) = n.
 intros.
 pattern m at 1.
 replace m with (n + (m - n)).
 apply other_lemma.
 symmetry; apply le_plus_minus; assumption.
Qed.
P.S.: I wouldn't recommend using such an unwieldy proof script in a real development, since this proof script also works (after you have run "Require Import Omega."):
   intros; omega.
