- From: Frederic Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Tactics and BigTerms in Coq
- Date: Thu, 23 Jun 2011 11:44:35 +0800
Le 23/06/2011 00:19, Laurent Théry a écrit :
Hello. I encountered similar problems recently with the apply tactic. It seems that bigger is the goal more time takes the apply tactic, even if the applied lemma is linear and first-order-like, which makes it useless with really big goals. Yet, applying a linear and first-order-like lemma to a goal should not depend on the size of the goal but only on the size of the lemma which is generally very small (this is first-order matching!). So, why it does not seem to be the case? Frederic.
Hi,
I'm experiencing a severe performance degradation when I am doing interactive proofs with very big terms in Coq.
Why is it so? Here is a stupid small example:
I define a dastructure and a lemma that makes the goal grow, and I test the time the tactic apply is taking:
Require Import Bool.
(* Binary trees *)
Inductive BTree := BLeaf (b : bool) | BNode (bT1 bT2 : BTree).
(* Stupid lemma to make things grow *)
Lemma BTinv: forall bt (bt1 := BNode bt bt), bt1 = bt1 -> bt = bt.
Proof. auto. Qed.
Lemma BTex: BLeaf true = BLeaf true.
Proof.
idtac "1-> 15". Time do 15 apply BTinv.
idtac "16". Time apply BTinv.
idtac "17". Time apply BTinv.
idtac "18". Time apply BTinv.
idtac "19". Time apply BTinv.
idtac "20". Time apply BTinv.
idtac "refl_equal". Time apply refl_equal.
Time Qed.
Compiling this with coqc I get (I'm using coq8.3pl1)
1-> 15
Finished transaction in 1. secs (0.884866u,0.007999s)
16
Finished transaction in 1. secs (1.132828u,0.010999s)
17
Finished transaction in 2. secs (2.008695u,0.026995s)
18
Finished transaction in 5. secs (4.437325u,0.037995s)
19
Finished transaction in 10. secs (9.628537u,0.331949s)
20
Finished transaction in 31. secs (28.279701u,1.209816s)
refl_equal
Finished transaction in 15. secs (12.974027u,0.905862s)
Finished transaction in 52. secs (51.655147u,0.158976s)
15 seconds for the refl_equal !!!! 52 second for the Qed!
If I try to build and check inside Coq the equality of two trees of height 20, it takes less
than 2 seconds:
Fixpoint eBt (bt1 bt2 : BTree) :=
match bt1 with
| BLeaf b1 =>
match bt2 with
| BLeaf b2 => eqb b1 b2
| _ => false
end
| BNode bt11 bt12 =>
match bt2 with
| BLeaf b2 => false
| BNode bt21 bt22 =>
match eBt bt11 bt21 with
| true => eBt bt12 bt22
| _ => false
end
end
end.
Fixpoint vBt (n : nat) :=
match n with O => BLeaf true | S n1 => let v := vBt n1 in BNode v v end.
Time Eval compute in
let v1 := vBt 20 in
let v2 := vBt 20 in eBt v1 v2.
(* Finished transaction in 2. secs (1.752734u,0.001999s) *)
- Re: [Coq-Club] Proof without "auto with arith", (continued)
- Re: [Coq-Club] Proof without "auto with arith", Jacques Garrigue
- Message not available
Lucian M. Patcas
AUGER Cedric
Lucian M. Patcas
Adam Chlipala
Lucian M. Patcas
- Re: [Coq-Club] Proof without "auto with arith", Adam Chlipala
- Re: [Coq-Club] Proof without "auto with arith", Stéphane Lescuyer
- [Coq-Club] Tactics and BigTerms in Coq, Laurent Théry
- Re: [Coq-Club] Tactics and BigTerms in Coq, AUGER Cedric
- Re: [Coq-Club] Tactics and BigTerms in Coq, Frederic Blanqui
- Re: [Coq-Club] Proof without "auto with arith", Lucian M. Patcas
Lucian M. Patcas
Adam Chlipala
Lucian M. Patcas
AUGER Cedric
Lucian M. Patcas
