coq-club - Re: [Coq-Club] Why is it wrong to declare a proven theorem as axiom?
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Why is it wrong to declare a proven theorem as axiom?
  • Date: Fri, 24 Jun 2011 15:03:38 +0200
On 06/24/2011 01:48 PM, Pierre Courtieu wrote:
*Replacing* T by T_ax may be useful (for efficiency if T is slow to
compile). It may seem unharmful however it may lead to inconsistencies
if you prove new theorems after that. Even if these theorems are not
about T itself. The reason is that the proof of T comes with universe
constraints which guarantee the consistency of the global proof
environment. Replacing T by T_ax would delete these constraints and
make coq accept proofs that would be inconsistent with the real proof
of T.
I would not call that "inconsistency". You have proven "T", and then you can prove "T -> False" (by deriving a contradiction from a new assumption of type T). But you can't prove False because when you try to feed the latter proof with the former, you get a type error (universe inconsistency). This situation can happen only when T is a compound expression involving "Type", which is an ambiguous notation for "some universe" on which you can put constraints, only in an indirect manner.
This is not so different from, say, "nat=nat is not the same type as nat=nat", because nat=nat might mean (eq Set nat nat) or (eq Type nat nat) which are not the same type. In the latter case, it's easier to spot the difference.
If you want to see a concrete instance, check out
http://coq.inria.fr/pylons/pylons/contribs/view/Paradoxes/v8.3 and
http://coq.inria.fr/pylons/contribs/files/Paradoxes/v8.3/Paradoxes.BuraliForti.html
There you can derive False from 3 assumptions A0 i0 inj and you can build A0 i0 inj with the same apparent types, but in fact these two occurrences rely on incompatible sets of universe constraints. (Unfortunately, coqdoc removed the comments that explain what's going on, so you'd better download the contrib sources).
An interesting question is: since in this case the potential
inconsistency would not be a consequence of T but a consequence of the
absence of the universe constraints of T, does this provide a way to
build a proof H of False such that Print Assumptions H = \emptyset?
This should not happen. As I said above, you could have a proof of T and a proof of ~T, without assumptions, when T contains Type, but not a single constant of type False without assumptions.
Maybe someone who knows how Print Assumptions works can tell? If yes
then this may be called a "fake proof that looks plausible to human
forensics". However there *is* an axiom somewhere in the environment
that should be detectable in some sense.
Complex reasoning sometimes need complex tools, and complex tools might be dangerous for people who don't know how to use them. Universe ambiguity in Coq is definitely complex (and some people will complain it's not as powerful and usable as it could be).
Who can address this challenge: find a "simple" statement T (simple in the sense that anyone with a minimal background in logics can understand) such that you can prove both T and ~T in Coq.
Bruno.
