coq-club - Re: [Coq-Club] wrong inference of an implicit argument
chronological Thread
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] wrong inference of an implicit argument
  • Date: Thu, 30 Jun 2011 16:11:22 -0700
Le 30 juin 2011 à 13:18, Vladimir Voevodsky a écrit :
> Consider the following code:
> Definition UU1 := Type .
> Definition UU2 := Type .
> Definition UU3 := Type .
> (* The following two lines establish that UU1 : UU2 *)
> Variable F : UU2 -> UU2 .
> Variable a : F ( UU1 ) .
> (* The following two lines establish that UU2 : UU3 and UU2 is a subtype of
> UU3 *)
> Definition subuu2uu3 : UU2 -> UU3 := fun X : UU2 => X .
> Definition inuu2uu3 : UU3 := ( fun X0 : UU3 => X0 ) UU2 .
> (* The following code produces universe inconsistency by failing to
> recognize that the type of [ t ] is [ UU1 ] . *)
> Definition test1 { T : UU3 } ( t : T ) := T .
> Variable t : UU1 .
> Variable b : F ( test1 t ) .
Hi Vladimir,
  You are thinking of test1 as being polymorphic on the universe level of T,
so that
if T is instantiated by UU1, then [test1 t : UU1 + 1]. This works if you set
definitions to be universe polymorphic when no type constraint is given, but
wouldn't
work if you defined instead:
Definition test1 { T : UU3 } ( t : T ) : UU3 := T.
The discrepancy is clear if you use an inductive definition of test1, which
automatically supports universe polymorphism:
Inductive itest1 {T:UU3} (t : T) :=
  intro_test1 : T -> itest1 t.
Then the [Variable b : F (itest1 t)] typechecks.
> I think in this situation the inference algorithm should either complain
> that there is an ambiguity or infer UU1 as the type of t ( in general it
> should choose the lowest universe to which is known to t belong ) .
I agree the type inference should find the lowest level possible, there's
been a few improvements in this respect recently, by making unification
actually aware of the sort
variables. It is however a different problem from making definitions
polymorphic.
I have a tentative patch for the later [1] (mainly the kernel/*.ml changes
are necessary),
and it seems not to cause any problem. It is also justified by Harper and
Pollack's
version of typical ambiguity with definitions.
[1]
https://github.com/mattam82/Coq-misc/commit/d98dfbcae463f8d699765e2d7004becd7714d6cf#diff-6
Hope this helps,
-- Matthieu
