- To: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] wrong inference of an implicit argument
- Date: Thu, 30 Jun 2011 19:38:33 -0400
I guess you are right. I checked again and for [ x : X ] , [ X : UU1 ] and
the value of [ test1 x ] is [ X ] but [ X ] moved into the universe [ UU3 ] .
It is weird because it means that from the point of view of Coq there are
*two different* types with the name [ X ] one in [ UU1 ] and another one in [
UU3 ] . A function [ F : UU1 -> UU1 ] can be applied to the first one but
not to the second .
Vladimir.
On Jun 30, 2011, at 7:11 PM, Matthieu Sozeau wrote:
> Le 30 juin 2011 à 13:18, Vladimir Voevodsky a écrit :
>> Consider the following code:
>> Definition UU1 := Type .
>> Definition UU2 := Type .
>> Definition UU3 := Type .
>> (* The following two lines establish that UU1 : UU2 *)
>> Variable F : UU2 -> UU2 .
>> Variable a : F ( UU1 ) .
>> (* The following two lines establish that UU2 : UU3 and UU2 is a subtype
>> of UU3 *)
>> Definition subuu2uu3 : UU2 -> UU3 := fun X : UU2 => X .
>> Definition inuu2uu3 : UU3 := ( fun X0 : UU3 => X0 ) UU2 .
>> (* The following code produces universe inconsistency by failing to
>> recognize that the type of [ t ] is [ UU1 ] . *)
>> Definition test1 { T : UU3 } ( t : T ) := T .
>> Variable t : UU1 .
>> Variable b : F ( test1 t ) .
> Hi Vladimir,
> You are thinking of test1 as being polymorphic on the universe level of T,
> so that
> if T is instantiated by UU1, then [test1 t : UU1 + 1]. This works if you
> set
> definitions to be universe polymorphic when no type constraint is given,
> but wouldn't
> work if you defined instead:
> Definition test1 { T : UU3 } ( t : T ) : UU3 := T.
> The discrepancy is clear if you use an inductive definition of test1, which
> automatically supports universe polymorphism:
> Inductive itest1 {T:UU3} (t : T) :=
> intro_test1 : T -> itest1 t.
> Then the [Variable b : F (itest1 t)] typechecks.
>> I think in this situation the inference algorithm should either complain
>> that there is an ambiguity or infer UU1 as the type of t ( in general it
>> should choose the lowest universe to which is known to t belong ) .
> I agree the type inference should find the lowest level possible, there's
> been a few improvements in this respect recently, by making unification
> actually aware of the sort
> variables. It is however a different problem from making definitions
> polymorphic.
> I have a tentative patch for the later [1] (mainly the kernel/*.ml changes
> are necessary),
> and it seems not to cause any problem. It is also justified by Harper and
> Pollack's
> version of typical ambiguity with definitions.
> [1]
> https://github.com/mattam82/Coq-misc/commit/d98dfbcae463f8d699765e2d7004becd7714d6cf#diff-6
> Hope this helps,
> -- Matthieu
- Re: [Coq-Club] wrong inference of an implicit argument, Matthieu Sozeau
- Re: [Coq-Club] wrong inference of an implicit argument, Vladimir Voevodsky
- Re: [Coq-Club] wrong inference of an implicit argument, Bas Spitters
- <Possible follow-ups>
- Re: [Coq-Club] wrong inference of an implicit argument, Georgi Guninski
