Re: [Coq-Club] Computing with Program Fixpoint using well-founded termination criteria
chronological Thread
- From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- To: David Pereira <dpereira AT liacc.up.pt>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Computing with Program Fixpoint using well-founded termination criteria
- Date: Wed, 6 Jul 2011 09:32:53 -0700
Hi David,
you can use [Print Opaque Dependencies dec] to find out which opaque lemmas
are used in the term.
-- Matthieu
Le 1 juil. 2011 à 10:46, David Pereira a écrit :
> Hi list members,
> I am currently implementing a decision procedure whose termination is
> based on a well-founded relation. I am using the Program Fixpoint command
> to implement such procedure. The code goes as follows:
> Program Fixpoint dec(sh : set re * set re)(sig:set A)(h:dec_p sh)
> {wf RAlg sh }:set re :=
> match one_iter sh sig with
> | (nv,l) as H0 =>
> match l with
> | Terminate => fst nv
> | Continue => dec nv sig (hhh (fst sh) (snd sh) sig
> (eee sh h) (fst nv) (snd nv) (refl_equal H0))
> end
> end.
> (* Obligations proved and made transparent with Defined *)
> The type [set re] is the type of finite sets of the Containers library by
> Lescuyer, the functions [hhh] and [eee] are defined transparently, the
> well-foundness proofs for [RAlg] where also made transparent, and the type
> [dec_p] is just the following Record:
> Record dec_p(sh:set re * set re) : Type := {
> H1 : fst sh[<=]PD r ;
> H2 : snd sh[<=]PD r ;
> D : \./ sh
> Definition hhh : forall s1 s2 sig,
> dec_p (s1, s2) -> forall s s0, (s, s0, Continue) = one_iter (s1, s2) sig ->
> dec_p (s,s0).
> Definition eee : forall sh, dec_p sh -> dec_p (fst sh,snd sh).
> Inductive DisjP(p:set re * set re) : Type :=
> | DisjP_0 : inter (fst p) (snd p) === {}%set -> DisjP p.
> Notation "\./ p" := (DisjP p).
> Everything went fine when developing all this stuff, but when it was time
> to execute [dec] within Coq, i.e, using Eval vm_compute in dec sh sig h,
> the evaluation simply seems to go on forever. I am pretty sure that it is
> due to well-foundness term used for the recursion. So, my question is : is
> there any standard tricks for enabling such a computation based on
> well-foundness when using Program Fixpoint? I know of a trick used by
> Thomas Braibant and Damien Pous that adds 2^n Acc_intro constructors in
> front of a well_foundedness proof, in order to keep the actual proof
> unreachable. Is this the standard trick, or there is any other one?
> Sorry if the message is confusing. Also I was not able to isolate the
> problem ir order to provide a script.
> Best regards to all,
> David Pereira.
- [Coq-Club] Computing with Program Fixpoint using well-founded termination criteria, David Pereira
- Re: [Coq-Club] Computing with Program Fixpoint using well-founded termination criteria, Stéphane Lescuyer
- Re: [Coq-Club] Computing with Program Fixpoint using well-founded termination criteria, Matthieu Sozeau
