- From: frank maltman <frank.maltman AT googlemail.com>
- To: <coq-club AT inria.fr>
- Subject: [Coq-Club] Quantified Prop argument not deleted by extraction?
- Date: Wed, 6 Jul 2011 15:52:42 +0000
On Wed, 6 Jul 2011 13:52:26 +0200
AUGER Cedric
<Cedric.Auger AT lri.fr>
wrote:
> > Inductive read_mode : Prop :=
> > | Read : read_mode
> > | Read_None : read_mode.
> > Inductive write_mode : Prop :=
> > | Write : write_mode
> > | Write_None : write_mode.
> I don't see any interest in providing such propositionnal types, as
> you won't be able to use them effectively.
> For instance, you won't be able to prove that "Read <> Read_None"
> (unless you use an axiom, but if so, you should have put it in Set/Type)
We wanted to guarantee erasure. Placing them in Set/Type caused them to
appear in extracted code. They exist solely to make it a type error
to attempt to read from a handle of type 'handle Read_None W S' or
write to a handle of type 'handle R Write_None S'.
> > Extracting this function results in:
> > let test =
> > open_truncate file_name (fun _ handle ->
> > order (write handle message) (pure ()))
> > Note that the argument to the function passed to
> > open_truncate is in the Prop sort but hasn't been removed
> > by extraction. The type of this function obviously doesn't
> > match what the O'Caml definition is expecting!
> I don't understand why you need this Prop parameter; have you read the
> manual about extraction? Have you tried Extraction Implicit?
> If not, do it; you may also consider taking a look in the Cocorico!
> wiki, about Extraction, or send a more complete (and parsable) file to
> give better explanations of what you want.
Yes, we've read it. Yes, we've tried Extraction Implicit.
Forget everything said above. The questions can be reduced to these:
--8<--
Axiom foo : forall {A : Set}, A -> (forall {S : Prop}, A -> A) -> A.
Extract Constant foo => "foo".
Definition bar (a : bool) :=
foo a (fun {S} x => x).
Recursive Extraction bar.
Result:
let bar a =
foo a (fun _ x -> x)
--8<--
Why does the '_' argument of type 'Prop' appear above? Shouldn't all
arguments in Prop be erased during extraction? How can this be prevented,
if at all?
- [Coq-Club] Quantified Prop argument not deleted by extraction?, frank maltman
- [Coq-Club] Job offer, Laurent Théry
- Re: [Coq-Club] Quantified Prop argument not deleted by extraction?, AUGER Cedric
- <Possible follow-ups>
