coq-club - Re: [Coq-Club] Quantified Prop argument not deleted by extraction?
chronological Thread
  • To: frank maltman <frank.maltman AT googlemail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Quantified Prop argument not deleted by extraction?
  • Date: Thu, 07 Jul 2011 13:14:33 +0200
Hello Frank,
I think this has nothing to do with Prop or not Prop, it is just that rank-2 arguments are never eliminated. That means, if you have a function type in a "higher-order" position, like the type
    (forall {S : Prop}, A ->  A)
which is the type of an argument of foo, then its arity is preserved by the extraction.
Here are more examples:
Definition g : forall C : Type,  (forall A : Type, bool -> bool) -> bool
 := fun C h => h bool true.
Extraction g.
(* results in
(** val g : (__ -> bool -> bool) -> bool **)
let g h =
  h __ True
The rank-1 "forall C" is removed, but not the rank-2 "forall A".
Definition g' : forall p : False,  (forall q : False, bool -> bool) -> bool
 := fun p h => h p true.
Extraction g'.
(* results in
(** val g' : (__ -> bool -> bool) -> bool **)
let g' h =
  h __ True
The proof argument "forall q" is not removed because it is a rank-2 quantification.
Cheers,
Andreas
On 7/6/11 5:52 PM, frank maltman wrote:
Axiom foo : forall {A : Set}, A ->  (forall {S : Prop}, A ->  A) ->  A.
Extract Constant foo =>  "foo".
Definition bar (a : bool) :=
   foo a (fun {S} x =>  x).
Recursive Extraction bar.
Result:
    let bar a =
      foo a (fun _ x ->  x)
--8<--
Why does the '_' argument of type 'Prop' appear above? Shouldn't all
arguments in Prop be erased during extraction? How can this be prevented,
if at all?
Andreas Abel  <><      Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
