- To: Marco Servetto <marco.servetto AT gmail.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] match/ proof of branch
- Date: Sun, 17 Jul 2011 09:23:53 -0400
Adam Chlipala wrote:
Here's the code, which will probably deserve some stepping-through and pondering. The [pattern] tactic is key to abstracting some uses of [f n] but not others, in a way that preserves well-typedness of the goal.
Oh, and I just noticed that the proof was depending on a hint introduced by [Require Import Program.], which I had there from when I was experimenting with [dependent destruction] (which didn't easily get the job done). You could either add that import or add an extra line [discriminate] to the end of the proof.
- [Coq-Club] match/ proof of branch, marco . servetto
- Re: [Coq-Club] match/ proof of branch,
Adam Chlipala
Marco Servetto
gallais @ ensl.org
- Re: [Coq-Club] match/ proof of branch, Adam Chlipala
Marco Servetto
- Re: [Coq-Club] match/ proof of branch, Pierre Courtieu
gallais @ ensl.org
Marco Servetto
Marco Servetto
Adam Chlipala
gallais @ ensl.org
Adam Chlipala
Marco Servetto
Marco Servetto
Adam Chlipala
Adam Chlipala
Adam Chlipala
