- From: "gallais @ ensl.org" <guillaume.allais AT ens-lyon.org>
- To: Adam Chlipala <adam AT chlipala.net>
- Cc: Marco Servetto <marco.servetto AT gmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] match/ proof of branch
- Date: Sun, 17 Jul 2011 15:29:32 +0200
Hi Adam,
My first guess would have been to follow closely
the function's definition with something like:
[pose (res := f n) ; destruct res ; simpl]
and it turns out to work:
Theorem rKFix:
forall(n: nat)(myR:R),
Some myR=rK n->data myR=n.
Proof.
intros n myR ; unfold rK ;
simpl ; intro H ; inversion H ; reflexivity.
Qed.
Is your approach more robust if we end up changing
rK's definition or is it more or less equivalent (I'm guessing
that pattern & pose do the same job here).
gallais
On 17 July 2011 15:20, Adam Chlipala
wrote:
> Marco Servetto wrote:
>> I have another problem with match-returns.
>> This time I can provide a very minimal working example.
>> Can someone help me in the proof of the last theorem? (nat and bool
>> are the standard ones)
> Oo, my chance to make up for my confused answer last time! :D
>> Definition f (x:nat):= true. (*some complex calculation I do not want
>> to unfold ever*)
>> Record R:= r{
>> data:nat;
>> cond: true=f data
>> Definition rK (n:nat):=
>> let res:=f n in
>> (match res as x return x=res->_ with
>> | true => fun p=> Some (r n p)
>> | false =>fun p=> None
>> end)(refl_equal res).
>> Theorem rKFix:
>> Proof.
> Here's the code, which will probably deserve some stepping-through and
> pondering. The [pattern] tactic is key to abstracting some uses of [f n]
> but not others, in a way that preserves well-typedness of the goal.
> Theorem rKFix: forall (n : nat) (myR : R),
> Some myR = rK n -> data myR=n.
> Proof.
> unfold rK; intros n myR.
> generalize (refl_equal (f n)).
> pattern (f n) at -2 -4 -5 -6.
> destruct (f n); simpl; intuition.
> injection H; intros; subst.
> reflexivity.
> Qed.
- Re: [Coq-Club] match/ proof of branch, (continued)
Adam Chlipala
Marco Servetto
gallais @ ensl.org
- Re: [Coq-Club] match/ proof of branch, Adam Chlipala
Marco Servetto
Pierre Courtieu
- Re: [Coq-Club] match/ proof of branch, AUGER Cedric
Pierre Courtieu
gallais @ ensl.org
Marco Servetto
Marco Servetto
Adam Chlipala
- Re: [Coq-Club] match/ proof of branch, gallais @ ensl.org
Adam Chlipala
Marco Servetto
Marco Servetto
Adam Chlipala
Adam Chlipala
Adam Chlipala
