- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: S3 <scubed2 AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Prove inductive type implies false in cycle
- Date: Tue, 02 Aug 2011 09:52:18 +0200
Hi,
In general, it's better to give non ambiguous inductive definitions.
In the attached file, I can build proofs of "divide 0 0" that use the
second constructor instead of the first one (lemma L1).
With the definitions divide' and divides'' (this one much better than
the first one), I can prove your simple lemma quite easily.
The last definition (divides'') makes the inversion tactic very easy to
apply.
Pierre
Start with a simple definition for divides evenly:
(Note: I know the arguments are usually written
the other way around. I arbitrarily decided to write
it in normal division operator order.)
Inductive divides: nat -> nat -> Prop :=
| divides_0 n: divides 0 n
| divides_n n m: divides n m -> divides (n + m) m
So, with this definition,
divides 0 0.
forall n, divides n 1.
forall n m, divides (n*m) n.
Those can all be easily and directly proven.
But, how would I prove that:
forall n, divides (S n) 0 -> False.
Normally, I would just use inversion,
but in this case, the predecessor is itself,
forming a cycle. What technique can you use
when you form a cycle?
Or should inductive definitions be
given in such a way as to avoid cycles to begin with?
..*.....**..***.*.........*.*...*..**..**game*.....*........|
*....*..**..*.*.*.*..*.**.*..*..*..**..**of**......**.***...|
*.**.*..**..*.*.**.**..**.**.****..***life.**.****..*.****..|
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.17 (GNU/Linux)
Comment: Using GnuPG with Gentoo - http://enigmail.mozdev.org/
iEYEARECAAYFAk43bBYACgkQxzVgPqtIcft3nQCfS2xHWVcodJ8v7unQ9gui1BzP
Au8An0dxUJZ+M/Fuz7ihxK3Pcr9r7OYv
=ZrqD
-----END PGP SIGNATURE-----
Lemma L1: divides 0 0.
change (divides (0+0) 0).
right.
right.
left.
Qed.
Lemma L0 : divides 0 0.
left.
Qed.
Inductive divides': nat -> nat -> Prop :=
| divides_0' n: divides' 0 n
| divides_n' n m: 0<m -> divides' n m -> divides' (n + m) m.
Lemma L2: forall m, divides' m 0 -> m =0.
induction m.
trivial.
inversion 1.
inversion H1.
Qed.
Inductive divides'': nat -> nat -> Prop :=
| divides_0'' n: divides'' 0 n
| divides_n'' n m: divides'' n (S m) -> divides'' (S (n + m)) (S m).
Lemma L3: forall m, divides'' m 0 -> m =0.
inversion 1.
trivial.
Qed.
- [Coq-Club] Prove inductive type implies false in cycle, S3
S3
- Re: [Coq-Club] Prove inductive type implies false in cycle, Brian Huffman
- Message not available
- Re: [Coq-Club] Prove inductive type implies false in cycle, Pierre Casteran
- Re: [Coq-Club] Prove inductive type implies false in cycle, AUGER Cedric
S3
